Problem with Bevel Adjustment on Milwaukee 12" sliding compound miter saw
Forum topic by Tamara posted 10-31-2013 04:29 PM 2818 views 0 times favorited 1 reply Add to Favorites Watch
View Tamara's profile
Tamara
2 posts in 1913 days
10-31-2013 04:29 PM
Topic tags/keywords: miter saw adjustments adjustment screw problem bevel adjustment problem blade square to table question problem bevel adjustment adjustment
Hello! I am new here and really hoping you guys might have a solution for me. We have the Milwaukee 12”sliding compound miter saw and the blade is not square to the table. I have tried adjusting the bevel per the manual instructions and further detailed instructions I found online. The problem I am having is that the adjustment screw doesnt seem to being doing ANYTHING. I wedge something behind the bevel lever to keep it in the middle position, loosen the two front screws then turn the adjustment screw and NOTHING. I can turn it all the way both ways and nothing about the blade changes. what am i missing? Everything says this should be super easy to do but absolutely nothing happens when I turn the adjustment screw. Thanks!
1 reply so far
View squazo's profile
squazo
120 posts in 1885 days
#1 posted 11-27-2013 03:02 AM
first off what is the model number so we can accurately help you
second here my best guess. check the hole the screw goes through, is it stripped. I
also the fence is sometimes knocked out of position, how is the fence secured. on my ridged that is how I adjust my fence. by loosening it and then squaring and tightening. though this might throw of your detents.
