milling rough cut lumber
Forum topic by LJD4662 posted 10-31-2013 03:49 PM 2137 views 0 times favorited 9 replies Add to Favorites Watch
View LJD4662's profile
LJD4662
35 posts in 1665 days
10-31-2013 03:49 PM
Topic tags/keywords: planer rough cut
I am new to wood working, and I have recently obtained some rough cut cypress. I want to make a bench out of it, but I would like to get it planed first. I do not have a planer so does any one have any suggestions on how I can get this done? Would a lumber yard be able to do this for me?
Thanks
9 replies so far
View mahdee's profile
mahdee
3870 posts in 1732 days
#1 posted 10-31-2013 03:53 PM
You can buy a hand planer for $20-$40. Some lumber yards and many saw mills have a planer.
-- earthartandfoods.com
16274 posts in 4183 days
#2 posted 10-31-2013 04:02 PM
I’m sure there are some lumberyards in the greater Baton Rouge vicinity that would plane your boards for a reasonable fee.
View del1del1's profile
del1del1
2 posts in 1633 days
#3 posted 10-31-2013 04:06 PM
a hand planer probly wont do what you want , it will leve uneven plane if the wood is bigger than the blade, , i don’t remember the hand planer size, i used to have one i belive 3 inch’s which would be ok for that width, i would try a cabnet shop they may have a sander or planer which would do the job, if they want to do this. i guess you don’t have many tool’s ? a belt sander would get some of the ruff saw marks off , but not real smooth , good luck
View HorizontalMike's profile
HorizontalMike
7749 posts in 2879 days
#4 posted 10-31-2013 04:23 PM
What Charlie says… Being as new to WW as you say, you don’t want to be turned off by the time, technique, and expertise it takes to plane a board flat by hand. My 2-cents…
View AandCstyle's profile
AandCstyle
3027 posts in 2222 days
#5 posted 10-31-2013 11:34 PM
You could make a router sled assuming you have a router. You would need to buy a bit such as this one or similar. HTH
-- Art
View GFYS's profile
GFYS
711 posts in 3436 days
#6 posted 11-01-2013 12:18 AM
Sounds like you have a “slab” you want planed? ..or is this Cyprus boards?
View Monte Pittman's profile
Monte Pittman
28919 posts in 2303 days
#7 posted 11-01-2013 12:26 AM
I would talk to lumber yards. What horizontal mike said is true. If you plane or sand it all by hand, your first experience will sour you on continuing this wonderful adventure. Good luck and ask questions when you need to.
-- Mother Nature created it, I just assemble it.
View Handtooler's profile
Handtooler
1542 posts in 2097 days
#8 posted 11-01-2013 01:14 AM
Even if you find a friend with a planer with newly sharpened blades to tackle this for you, just be advised that dry Cyprus with its tall catheradalls is very likely to have them turn loose and curl up some before you get it home. This isn’t a tremendous problem but will take some additional sanding to get a ready to finish piece. I’ve been using Cyprus taken off my house 27 years ago and constantly been sroried stickered indoors ever since and I experience this event often. Maybe some LJ’s can advise as to how to best reduce this from happening?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
View gfadvm's profile
gfadvm
14940 posts in 2655 days
#9 posted 11-01-2013 01:28 AM
Handtooler, I have the same issues with flat sawn Doug Fir and haven’t found a way to solve it yet. My cypress was better than the Doug Fir but I think I’m gonna QS or Rift saw the next log.
