Tabletop glue up
Forum topic by Mcqueen posted 10-31-2013 03:22 PM 1088 views 0 times favorited 10 replies Add to Favorites Watch
View Mcqueen's profile
Mcqueen
3 posts in 1538 days
10-31-2013 03:22 PM
Topic tags/keywords: coffee table tabletop
Hi,
I’m planning on building a coffee table using cherry. I want it to be 2” thick with the dimensions 48” x 34”. I was planning on having wide boards, 7”-10” to make up the top but now that I research more I am afraid of cupping. Any advice on how to proceed, any tips? Are the boards thick enough that this won’t be a problem?
Thank you.
10 replies so far
View AandCstyle's profile
AandCstyle
2946 posts in 2127 days
#1 posted 10-31-2013 11:59 PM
I have a few thoughts about this project:
1. If you truly want a 2” thick surface, you will need to find at least 10/4 stock and plane it down. It might be difficult to find cherry in that size.
2. If the wood is dried to about 8% moisture content and you allow it adequate time to acclimate to your shop, cupping shouldn’t be an issue.
3. If you alternate growth rings facing up and down, any cupping will be offset to some extent by each board’s neighbors. However, there has been some discussion about the validity of this practice and the results.
4. You might consider adding breadboard ends to help hold the top flat.
5. A top of this size will weigh about 70 pounds, so good luck with moving it around.
Good luck and post pix.
-- Art
View michaelsgarage's profile
michaelsgarage
71 posts in 1796 days
#2 posted 11-01-2013 12:14 AM
cauls, cauls, cauls. and alternate clamps.
View MarkwithaK's profile
MarkwithaK
370 posts in 3048 days
#3 posted 11-01-2013 12:16 AM
My first thought was breadboard ends as mentioned above.
I would also consider letting the wood acclimate to it’s intended space. I did a similarly sized table top and while it was fine in the shop after a few months in the mouse it began to move all over the place to the extent that at times I could literally hear it crack.
-- If at first you don't succeed then maybe skydiving isn't for you.
Mcqueen
#4 posted 11-01-2013 12:34 AM
Thank you for your replies. I was eyeing 8/4 stock that is already s4s (or in some cases s3s) . Do you think I would still need to plane s4s boards? I anticipate some minor hand planing.
Thank you again
View Monte Pittman's profile
Monte Pittman
27649 posts in 2208 days
#5 posted 11-01-2013 12:36 AM
Wood is going to move. The more stable the environment, the less it will move. One thing I do is put a good finishing sealon the underside of the table top. Seal it as well as possible. Many put heavy finish on the top and none on the bottom. So the bottom changes with the humidity in the room. It can actually cause more damage because of unequal movement. At least that’s my theory and I am sticking to it.
-- Mother Nature created it, I just assemble it.
MarkwithaK
#6 posted 11-01-2013 12:38 AM
Perfectly viable theory Monte.
View Clint Searl's profile
Clint Searl
1533 posts in 2231 days
#7 posted 11-01-2013 01:29 AM
2” is too thick. Breadboard ends will NOT prevent warping.
View CrazeeTxn's profile
CrazeeTxn
151 posts in 1820 days
#8 posted 11-01-2013 01:45 AM
Don’t get in a hurry. Don’t think it’ll help with cupping as some great ideas have been thrown out there.
Glue two edges together at a time vs. trying to glue the whole dang thing up at once. This will allow you an opportunity to get the seams as level together as possible to eleviate A L O T of extra sanding. I usually practice this theory, but thought I could get away with it on a bar top I made (which I did alternate ring patterns on), but I probably spent more time and sandpaper on it sanding than I did taking it from rough to finished.
Mcqueen
#9 posted 11-01-2013 01:56 AM
2” is too thick to warp or 2” is too thick of a tabletop?
View lateralus819's profile
lateralus819
2241 posts in 1759 days
#10 posted 11-01-2013 02:12 AM
Ill 2nd crazee. My first time i glued way to many together at a time. What a mess. I’d stick to 2/3 at most. Get the joints as perfect as possible. Saves having to remove excess materials.
Breadboards would be a good alternative.
