What happens if you run a dust collector impeller in reverse?
« back to Hand Tools forum
Forum topic by Loren posted 10-31-2013 01:06 AM 1030 views 0 times favorited 5 replies Add to Favorites Watch
View Loren's profile
10477 posts in 3887 days
10-31-2013 01:06 AM
Does it blow the air the opposite direction or just not
work as well as it should?
I have a 3 phase dust collector. Opening it up to see the
impeller direction would be a hassle. I just wired in a
new remote switch. 3 phase motors reverse by switching
2 of 3 hot wires.
This is why I am asking.
5 replies so far
View Monte Pittman's profile
Monte Pittman
30153 posts in 2578 days
#1 posted 10-31-2013 01:14 AM
Shouldn’t hurt anything. Just turn backwards.
View REO's profile
REO
929 posts in 2314 days
#2 posted 10-31-2013 02:17 AM
wont work as well. it is a centrifugal blower so the air will still go in the center and be forced out to the outside and out the outlet. you should be able to look at the fan on the back end of the motor and determine direction without actually having to look at the impeller.
#3 posted 10-31-2013 02:18 AM
Ah – great idea. Thanks.
#4 posted 10-31-2013 03:29 AM
That did the trick. It was running backwards.
View crank49's profile
crank49
4032 posts in 3211 days
#5 posted 10-31-2013 04:05 AM
Lucky it wasn’t a TENV motor.
