Holdfast in MDF bench top
« back to Hand Tools forum
Forum topic by Christian Holihan posted 10-30-2013 05:11 PM 2673 views 0 times favorited 11 replies Add to Favorites Watch
View Christian Holihan's profile
Christian Holihan
85 posts in 1821 days
10-30-2013 05:11 PM
Topic tags/keywords: workbench holdfast
I have a laminate bench top of 3 1” MDF boards. Is it beyond foolish to drill a hole for a hold fast? Is there enough strength and thickness for the holdfast to work properly?
Here is a good shot of the bench when is was new and clean.
Any advice would be welcome.
-- Nobody deserves particle board | http://artisancare.org
11 replies so far
View bondogaposis's profile
bondogaposis
4755 posts in 2374 days
#1 posted 10-30-2013 05:30 PM
You could give it try, I can’t say if it would work or not. I would recommend that you chamfer the hole to avoid tear out.
-- Bondo Gaposis
View Deltarich's profile
Deltarich
23 posts in 3511 days
#2 posted 10-30-2013 05:35 PM
I would consider one of these vs a traditional hold-fast for mdf to help reduce tear out from pounding. http://www.leevalley.com/en/wood/page.aspx?p=31149&cat=1,41637
View Kaleb the Swede's profile
Kaleb the Swede
1835 posts in 1992 days
#3 posted 10-30-2013 05:35 PM
How about a T-track with hold downs. I use them in my work bench and they are indispensable. All you would have to do is rout a groove for the t-track and screw them in. The hold downs can be taken out when not needed
Something like this
http://www.grizzly.com/products/Hold-Down-Clamp-for-T-Slot-Track/D2726
-- Just trying to build something beautiful
View Don W's profile
Don W
18754 posts in 2590 days
#4 posted 10-30-2013 06:15 PM
I’d look for something along these lines.
View Tedstor's profile
Tedstor
1643 posts in 2655 days
#5 posted 10-30-2013 06:35 PM
I have one of these. They take a minute to install and remove after each use, but nothing too tedious.
4998 posts in 2516 days
#6 posted 10-30-2013 06:45 PM
Just a guess, but I’d bet it would work. But maybe only for a while, I’d think the holes would get misshapen and worn out form continual use.
View GrandpaLen's profile
GrandpaLen
1650 posts in 2295 days
#7 posted 10-31-2013 12:25 PM
Try it in the MDF, if that fails you could enlarge the hole to 2” to 3” and fill it with a hardwood dowel turned on a lathe, a short section of hardwood hand rail, an ash or hickory baseball bat, and then rebore a 3/4” hole.
Could also be replaced with square stock.
...just a thought FWIW.
Best Regards. – Grandpa Len.
Work Safely and have Fun.
-- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana.
View 489tad's profile
489tad
3368 posts in 3034 days
#8 posted 10-31-2013 01:05 PM
I have a laminated plywood with a hard board top. I put an oak board on the underside where the hols are. So far so good.
-- Dan, Naperville IL, I.G.N.
View Wdwerker's profile
Wdwerker
333 posts in 2256 days
#9 posted 10-31-2013 01:33 PM
I would coat the inside of the holes with some finish to harden and waterproof the MDF. I bet a small foam brush would do the trick.
-- Fine Custom Woodwork since 1978
Christian Holihan
#10 posted 10-31-2013 10:47 PM
Tons of solid advice from everyone. Thanks!
Shawn Masterson
1325 posts in 1971 days
#11 posted 10-31-2013 11:54 PM
i believe it would work for a while. I think the problem would be the long run. the whole would wollar out pretty fast from repeated use.
