Ends of board burning when I cut them? Solution?
Forum topic by Micah Muzny posted 10-30-2013 03:40 PM 1192 views 0 times favorited 9 replies Add to Favorites Watch
View Micah Muzny's profile
Micah Muzny
185 posts in 1850 days
10-30-2013 03:40 PM
I am working on a project and when I make a cut with my circular saw the plywood burns on the ends where I cut. I am using my new DeWalt 15 amp worm-drive circular saw with a Freud Diablo Ultra finish Blade. Both the saw and the blade are brand new out of the box the same day I cut the wood. I am cutting 3/4 inch Red Oak plywood, so I know the 15 amp saw is not going to be under powered for the job. Could it be the the Ultra finish blade with the 60 teeth doing the burning, or would that not matter? Am I going to slow? If I go faster than the speed I was going, if feels like I am forcing it. Perhaps my blade needs straightening? I just don’t know, any tips or suggestions would be helpful. Thanks!
9 replies so far
View Loren's profile
10477 posts in 3766 days
#1 posted 10-30-2013 03:43 PM
How far out do you have the blade protruding below
the saw base plate?
View Tedstor's profile
Tedstor
1662 posts in 2751 days
#2 posted 10-30-2013 03:44 PM
Feed rate too slow?
Are you using a straight edge? Maybe you’re feeding the saw into the wood at a crooked angle- thus the blade is becoming slightly binded?
60 teeth does seem excessive on a 7.25” blade- for plywood. But I’d think it’d still work OK. Especially if it were new.
View UncannyValleyWoods's profile
UncannyValleyWoods
542 posts in 1982 days
#3 posted 10-30-2013 03:53 PM
You’re going to have to make a sacrificial offering to your saw. Follow these steps.
1. Build a bond fire.
2. Put seven pieces of Ikea furniture onto the bond fire.
3. Pour seven beers on the ground.
This should pacify your saw.
-- “If Jesus had been killed twenty years ago, Catholic school children would be wearing little electric chairs around their necks instead of crosses.” ― Lenny Bruce
View chrisstef's profile
chrisstef
17631 posts in 3124 days
#4 posted 10-30-2013 04:08 PM
Not the beer! ^
Ok maybe 7 Michelob Ultras but no real beer please.
View ScottKaye's profile
ScottKaye
681 posts in 2071 days
#5 posted 10-30-2013 04:58 PM
Micahm,
Check your fence alignment to your blade. I bet is not parallel. I had this same issue with a POS Craftsman.
-- "Nothing happens until you build it"
View dschlic1's profile
dschlic1
441 posts in 2088 days
#6 posted 10-30-2013 05:09 PM
I second the issue of blade alignment. When I purchased my circular saw, the blade was over 1/8” out of alignment with the edge of the base. It took me the better part of a day to get it lined up. I use a Diablo fine blade and have no issues with burning.
View moke's profile (online now)
moke
1229 posts in 2894 days
#7 posted 10-30-2013 05:11 PM
Uncanney—-correct me if I’m wrong, but don’t you have to wear two pair of yellow socks too?
Mike
-- Mike
UncannyValleyWoods
#8 posted 10-30-2013 06:52 PM
moke- I do believe you are correct. Yellow socks and it wouldn’t hurt to wear a pair of his wife’s panties as well (also yellow).
View pintodeluxe's profile
pintodeluxe
5741 posts in 2931 days
#9 posted 10-30-2013 07:00 PM
It sounds like the feed rate changes near the end of your cut. If the burning only occurs at the ends of the cut, it is likely feed rate. I solved this problem by using an extra-long edge guide, so I could cut past the workpiece without slowing down much.
