How to glue mdf edge to edge
« back to Joinery forum
Forum topic by ashahidan posted 10-30-2013 03:31 AM 4880 views 0 times favorited 6 replies Add to Favorites Watch
View ashahidan's profile
ashahidan
64 posts in 3120 days
10-30-2013 03:31 AM
I have a few pieces of one inch thick, 5 by 8 inches of mdf board. I have tried joining them to make a few bigger pieces with white glue but the edges would’‘t stick together. The edges seem suck the glue into the fiber. I then tried using fiberglass glue. This also failed.
Is there any other ways to glue mdf edge to edge?
Shahidan
-- asm
View Loren's profile
10476 posts in 3669 days
#1 posted 10-30-2013 03:48 AM
You may have success making a glue sizing out of glue
thinned with water. Apply 1 coat and let it dry, then
another. This should be enough to keep future glue
from sucking into the MDF edges.
View tefinn's profile
tefinn
1222 posts in 2458 days
#2 posted 10-30-2013 03:49 AM
MDF doesn’t join together like real wood will. You will need to use some type of dowels, biscuits or mechanical fastener like pocket screws. You might also try polyurethane glue or epxoy. Whatever you use the joint won’t have any real structural strength like edge joined wood. If you dont support it from below and put weight on it, it will break.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
View rockindavan's profile
rockindavan
299 posts in 2658 days
#3 posted 10-30-2013 03:50 AM
Biscuits or dominos…or maybe start with a bigger board lol
View NiteWalker's profile
NiteWalker
2737 posts in 2598 days
#4 posted 10-30-2013 04:15 AM
+1 on biscuits or dowels, but if you can, use a new board.
View waho6o9's profile
waho6o9
8204 posts in 2598 days
#5 posted 10-30-2013 04:19 AM
How about using a spline?
ashahidan
#6 posted 10-30-2013 02:52 PM
Thank you for your suggestions.
I appreciate your suggestions but as you all say the joint would not be strong I might as well use the boards for other small projects.
Epoxy is rather expensive for me.
Thank you again.
-- asm
