Microwave blower motor filtration
Forum topic by onecarwallace posted 10-29-2013 04:24 PM 1114 views 0 times favorited 7 replies Add to Favorites Watch
View onecarwallace's profile
onecarwallace
17 posts in 1589 days
10-29-2013 04:24 PM
Topic tags/keywords: air filtration dust collection safety blower motor
Has anyone here ever tried making an air filtration system using the blower motor out of an over-the-range microwave, like this?
I found a post from someone that stated that he did it but there was no other info regarding the performance. All I can find on the subject is people using furnace blowers, which are probably a lot more powerful. Mind you, I’m in a one car garage so I don’t need that many CFMs to filter all the air.
Thanks!
7 replies so far
View crank49's profile
crank49
4028 posts in 2842 days
#1 posted 10-30-2013 03:36 AM
You could do better with a 20” box fan with a 20” x 20” furnace filter duct taped to one side of it.
Heck of a lot cheaper as well.
View rockindavan's profile
rockindavan
299 posts in 2507 days
#2 posted 10-30-2013 04:01 AM
I used a squirrel cage fan to clear the air from a small 6×6 make shift spray booth and it worked quite well. Getting an effective air cleaner however from one of those fans might not work as well as you hope. To be effective you need enough airflow to circulate the air around the shop in addition to pulling air through the filter. Anyways give it a shot if you have it sitting around. You should be able to swap it out with a bigger fan if it doesn’t work well.
TopamaxSurvivor
18162 posts in 3547 days
#3 posted 10-30-2013 04:40 AM
I doubt it will move enough air.
onecarwallace
#4 posted 10-30-2013 12:57 PM
I was asking because I already have a microwave blower motor. My microwave died a while ago and I pulled it out before throwing the rest of it away, so no cost. I know this is unscientific, but it feels like it could be pulling more CFMs than a box fan. It’s small, but really powerful.
I actually built this setup but I feel like it isn’t doing anything. I have maybe about 8 inches of gap between the top of the filter and the ceiling so that the outlet air flow isn’t obstructed, but it probably doesn’t do too much in terms of actually circulating the air.
The plan was to see if I could build a better filter with the small blower motor before just buying an overhead air filtration system.
TopamaxSurvivor
#5 posted 10-30-2013 03:58 PM
Let us know if it works.
View Tedstor's profile
Tedstor
1643 posts in 2504 days
#6 posted 10-30-2013 04:07 PM
I too think a range fan is too small to move significant amounts of air.
View b2rtch's profile
b2rtch
4847 posts in 2920 days
#7 posted 10-30-2013 04:46 PM
You need a lot of CFM, I know that such a small fan cannot deliver.
” Mind you, I’m in a one car garage so I don’t need that many CFMs to filter all the air.”
Wrong, you do need the big CFM to move all the air in your garage and not only a few inches around the fan
-- Bert
