Forum topic by HarveyDunn | posted 10-29-2013 01:17 PM | 15691 views | 1 time favorited | 24 replies | ![]() |
Topic tags/keywords: question chisel joining Hi all, Can I get a clean dadoes, rabbet or groove using hand-tools only, without using a specialty plane? I’m going to sharpen up a chisel today and start practicing on some scrap wood. I’m wondering how to control the depth. I was thinking of measuring the desired depth on my saw blade and/or chisel, drawing a line there with a Sharpie, then sawing/chopping until that line is level is with the face of the board. And then pare out the waste and sand. |
24 replies so far
#1 posted 10-29-2013 01:24 PM |
Yes you can. Check out the “Poor Man’s Router Plane” by Paul Sellers. Here’s the Blog Post >> http://paulsellers.com/2012/06/pauls-poor-mans-router/ And the Video >> http://www.youtube.com/watch?v=B2aFwjAgk Or the advanced version that uses a hex key >> http://paulsellers.com/2012/03/not-so-poor-mans-router-really-works/ -- Men have become the tools of their tools. - Henry David Thoreau |
#2 posted 10-29-2013 01:24 PM |
Check out this video from The English Woodworker blog for chopping out the majority. Then, to clean up the bottom, you could use Paul Seller's poor man's router -- In matters of style, swim with the current; in matters of principle, stand like a rock. Thomas Jefferson |
#3 posted 10-29-2013 01:36 PM |
+1 on what JayT posted. I did that on the last cabinet I built. |
#4 posted 10-29-2013 01:45 PM |
Thanks guys, but: |
#5 posted 10-29-2013 01:54 PM |
Are you trying to avoid power tools for the sake of seeing if it can be done or is there some other reason? I only ask, because if you don’t have a router, you can get a good used one usually for less than $50 and get what bit you need when you need it vs. buying a set. I know it may sound a little nosey, but in my profession, it’s important to understand why something needs to be a certain way to solve the problem presented. |
#6 posted 10-29-2013 01:58 PM |
No problem, bigblockyeti. I’m setting up a workspace in a spare room inside the house, on a budget. So I am both pinching my pennies and trying to avoid creating noise and not fling swarf, and sawdust everywhere. |
#7 posted 10-29-2013 02:06 PM |
personally I would make the router plane from the chisel, but you could clamp some stops on your saw to make it similar to a stair makers saw. -- http://timetestedtools.net - Collecting is an investment in the past, and the future. |
#8 posted 10-29-2013 02:33 PM |
Getting an exact depth without a jig such as the poor man’s router plane takes practice, but can be done. Shannon Roger’s shows one method using just a chisel here >> http://www.renaissancewoodworker.com/chiseling-a-rabbet/ And here>> https://www.youtube.com/watch?v=-Ypbvcxb-8M if you skip to the middle (about 14:43 through 25:46 minutes) Paul Sellers demonstrates a similar technique while making a shooting board. Paul & Shannon are great resources for hand tool skills, both present the knowledge very well, and don’t encourage the average woodworker to spend huge $$ on jigs & tools. BTW, I’m a big fan of the Sharpie, but I prefer a 0.5mm mechanical pencil in the shop. In a pinch, I have beveled the lead in a carpenters pencil to a knife edge and used that to mark very fine lines. The edge doesn’t last for more than a few lines, but can be easily touched up on some sandpaper. -- Men have become the tools of their tools. - Henry David Thoreau |
#9 posted 10-29-2013 04:04 PM |
Cutting gauge can help. Easy to make one. Dado cheeks used to be sawn with a dado saw, a long |
#10 posted 10-29-2013 04:11 PM |
Yeah, the noise, especially inside, I can imagine would be unacceptable for most. Even if the router and bits were free! |
#11 posted 10-30-2013 01:37 AM |
Paul Seller’s poor man’s router isn’t really a specialty plane, it’s a chisel stuck through a 2×4. But if you consider that a speciality plane and want to avoid that for some reason, then yes, you can mark the depth, cut the sides with a saw and chisel out the middle. You still need to do that first with a router plane or the poor mans router anyway because they are best only for the last 1/16” or so. Like Loren and other said, buy or make a marking gauge though, it will be much more accurate than marking with a sharpie. |
#12 posted 10-30-2013 02:04 AM |
Sorry, I got confused, I thought Paul Seller’s poor man’s router was the homemade router plane made with a ground hex key. Thanks for the correction. I mentioned the Sharpie as a means to mark the stop line on the chisel or the saw…not the wood. |
#13 posted 10-30-2013 03:09 AM |
I would use tape rather than a sharpie. I wouldn’t want to mark up my saws. And trust me, I feel your pain on not wanting to make that big of a mess or noise… my shop is the spare bedroom in my apartment, for the past year and a half. I would recommend getting a router plane, at some point, though. It makes life a lot easier. -- Mos - Twin Cities, MN - http://www.youtube.com/MosquitoMods - http://www.TheModsquito.com |
#14 posted 10-30-2013 03:33 AM |
Router plane = less noise than hammer and chisel -- Don't anthropomorphize your handplanes. They hate it when you do that. -- OldTools Archive -- |
#15 posted 10-30-2013 04:31 AM |
The noise comparison was not router plane vs. hammer and chisel but power router vs. hand tool. Also, I already own a hammer and a set of chisels. I’m drawing up a project that is going to require various kinds of grooves and rabbets varying from 1/8” to 3/4”. It would be awesome if I could make them all with what I already own rather than trolling for vintage planes on eBay for days/weeks looking the perfect combination of condition and price. |
Forum | Topics |
Woodworking Skill Share
12033 |
Woodturning
2108 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4907 |
6696 |
28067 |
CNC Woodworking
212 |
Hand Tools
5412 |
Jigs & Fixtures
1420 |
Wood & Lumber
6233 |
1388 |
Focus on the Workspace
2154 |
1187 |
Woodworking Trade & Swap
4759 |
LumberJocks.com Site Feedback
2201 |
Coffee Lounge
8846 |
