Coarse, Medium & Fine Hand Planes for a Newbie
« back to Hand Tools forum
Forum topic by HarveyDunn posted 10-28-2013 05:30 PM 2053 views 1 time favorited 69 replies Add to Favorites Watch
View HarveyDunn's profile
HarveyDunn
328 posts in 1600 days
10-28-2013 05:30 PM
Topic tags/keywords: hand planes question plane milling
I’m a novice woodworker. I’m looking for a low-cost way to get a coarse, medium & fine hand plane for squaring up my boards and then perfecting the surface so I can do as little sanding as possible (I work in a spare room inside the house, so sawdust is a huge issue. Wispy shavings, not so much.)
I know the standard recommendation is to buy vintage Stanleys on eBay. My research tells me that I’d be happy with a #5 as my fore plane (i.e. my “coarse”), a #7 as my jointer (i.e. my “medium”), and a #3 or #4 as my smoother (i.e. my “fine”).
Unfortunately, eBay isn’t quite the bargain wonderland that I had hoped it would be. Those three planes would cost around $200 by the time shipping is included. And what will I actually find when the box arrives? Since I don’t have a well-equipped shop, if there is anything wrong with any of them that needs fixing, I’ll have to spend additional money on tools and supplies to get them up-to-scratch. And, to be honest: I’m not completely sure that I’d really know what I’m doing, no matter how many blog posts I read.
I did find a used tool dealer who said he could set me with all three in “good working order” for $250, which I thought was fair. The best he could say about the dates was they would all be pre-1970.
There is another option: a brand new WoodRiver No. 5 with three blades. One with a major camber for coarse, one with a minor camber for medium, and one with a slight camber for fine. Woodcraft is having a sale, so I can get it all for $180, delivered.
But I don’t own a grinding wheel, or any diamond, water or oil stones. I do have a piece of float glass and a cheap honing guide for “scary sharp”. Can I camber a blade with just that (and maybe a file?)
And input about any of these ideas, or any better ideas?
There was an article in FWW Jan/Feb ‘11 about using a LN 62 LA Jack with FOUR different blades – one was angled specifically for end grain and use with a shooting board. Total cost at current prices: $390. Out of my league, but it does make me wonder if I need to think about a four blade for the WoodRiver, or a fourth vintage plane if I decide to go that route.
69 replies so far
View Tedstor's profile
Tedstor
1643 posts in 2502 days
#1 posted 10-28-2013 05:46 PM
Just to complicate things…...I’ll recommend you add a block plane to that list.
Google-Brass City Records and check out Walt’s tool selection. I’m thinking you could get everything you needed, including a block plane, for $200ish. And its a safe bet that the planes you recieve would need minimal tune-up. I’ve ordered several tools from BCR, and they’ve all been virtually ready-to-use upon delivery. Give Walt a call and tell him what your trying to do. He’ll hook you up.
Having one plane and various blades seems too fussy for me. And blades cost $30+ each, so the savings might not be overly significant compared to buying old Stanleys. I’m not the biggest hand tool user, so others might disagree, but I’m thinking you’d be better served with a smoother, jointer, and a block plane. And I feel you should buy the block plane first. I don’t personally deal with a lot of long boards, so I don’t even have a jointer. I get by with a jack plane.
HarveyDunn
#2 posted 10-28-2013 05:49 PM
Thanks Tedstor. For which tasks do I need the block plane?
View Don W's profile
Don W
18554 posts in 2437 days
#3 posted 10-28-2013 05:50 PM
Take a read here, https://timetestedtools.wordpress.com/2012/05/02/what-planes-do-i-need/
Tedstor
#4 posted 10-28-2013 05:53 PM
I use my block plane multiple times, on virtually every project. Cleaning-up joints mostly. Chamfering/shaping edges too. Pretty much anytime a larger plane would be impractical…..which is often.
Tedstor
#5 posted 10-28-2013 05:57 PM
Don’s link sums it up well.
View WayneC's profile
WayneC
13751 posts in 3967 days
#6 posted 10-28-2013 06:03 PM
I do not like what your tool dealer offered you from both an age and a price perspective. Think you have not found the right dealer. If you like, I could start suggesting handplanes on ebay for you to consider.
You are looking for planes that are from about 1910 to 1940.
View chrisstef's profile
chrisstef
17096 posts in 2876 days
#7 posted 10-28-2013 06:04 PM
You can certainly sharpen an iron with a guide and a pile of sandpaper but what I think you will be missing by not tuning up a plane by yourself is the inner working of the tool.
Until I totally took one apart, fussed with all the settings, and put it back together I couldn’t understand what made it work and more importantly, what made it not work. There isn’t a ton of moving parts inside and outside of a plane but there are enough that one errant miscalculation can lead to frustration.
If you would like, Id like you to spend your money elsewhere. You PM me where I can send it and ill ship you out a Millers Falls 14 jack plane (equivalent to a #5). Its been mostly derusted of the heavy stuff but does have a little surface rust on it from me not treating it right after its initial bath. Its in very good shape but does need the sole flattened, the iron sharpened, and the frog and chipbreaker dialed in. I can even post you a pic tonight if youd like.
We (LJ’s) will walk you through the restoration / refurb step by step if you need the help. We’re nothing but a bunch of enablers any way.
WayneC
#8 posted 10-28-2013 06:07 PM
Here is a good example of a #3
http://www.ebay.com/itm/1925-1928-Stanley-Bailey-3-Wood-Plane-Type-13-Sweetheart-Blade-/310774911903?pt=US_Hand_Tools&hash=item485ba0d39f
Don W
#9 posted 10-28-2013 06:09 PM
Well said!!
WayneC
#10 posted 10-28-2013 06:14 PM
Here is a #5 that would be a good restore candidate…
http://www.ebay.com/itm/Old-Bailey-Wood-Plane-No-5-Patd-Date-/121199350601?pt=LH_DefaultDomain_0&hash=item1c380b5349
WayneC
#11 posted 10-28-2013 06:20 PM
Good example of a restore-able #4.
http://www.ebay.com/itm/Vintage-Stanley-Bailey-No-4-Wood-Plane-with-Patd-Dates-of-1902-and-1910-/350901680138?pt=LH_DefaultDomain_0&hash=item51b35eb80a
WayneC
#12 posted 10-28-2013 06:24 PM
WayneC
#13 posted 10-28-2013 06:27 PM
WayneC
#14 posted 10-28-2013 06:28 PM
LOL. Done enabling
View JayT's profile
JayT
5488 posts in 2080 days
#15 posted 10-28-2013 06:33 PM
I put out this offer in the Handplanes of Your Dreams thread, but to reiterate, I have a very nice Millers Falls #9B smoother (same size as a Stanley #4) that is yours for the asking, just PM me an address. With that and chrisstef’s offer for a jack, you would be well on your way.
Edit: This one is tuned up and ready to go, so you would have something to compare the jack to as you worked it over.
showing 1 through 15 of 69 replies
