Help with finishing a wall mounted bottle opener
Forum topic by scrapbmxrider16 posted 10-28-2013 11:57 AM 1075 views 0 times favorited 8 replies Add to Favorites Watch
View scrapbmxrider16's profile
scrapbmxrider16
19 posts in 1915 days
10-28-2013 11:57 AM
Hello,
I am looking for help on finishing a wall mounted bottle opener. I am looking for a high gloss and durable finish.I have always finished with wipe on poly. Are there any other options? The opener is walnut with maple inlays.
8 replies so far
404 - Not Found
2544 posts in 3204 days
#1 posted 10-28-2013 12:35 PM
If it’s got awkward contours, spraying is probably best. Look for a high gloss rattle can – but practice first.
View crank49's profile
crank49
4032 posts in 3206 days
#2 posted 10-28-2013 12:56 PM
Paint?
Paint doesn’t get any more durable than Dupont Imron.
Or more expensive either.
scrapbmxrider16
#3 posted 10-28-2013 07:19 PM
Why in the world would you paint walnut with maple inlays?
404 - Not Found
#4 posted 10-28-2013 07:36 PM
I’ll expand on my answer a little. I choose spraying as it will not leave any brush marks, also, for any awkward contours where you’d have difficulty getting a brush, roller or cloth in, spray fits the bill. The trouble is, I don’t know what rattle cans are available in your neck of the woods. I have used and been disappointed by water based clear coats out of a rattle can, but that might be due to the limited selection over here – but if you go into a car spares/accessories shop and pick up an aerosol of cellulose lacquer, you might be in with a chance of achieving the finish you desire. (Don’t spray it indoors) The alternative would be to apply a poly finish, wait for it to cure and rub out the finish with auto rubbing compounds, but it all depends on how much you are willing to put into the job.
If you are going the auto route, get it all sanded down to say 220/240 first, wipe off with MS and try and get a good wet coat on without any runs, let it dry and if it needs denibbing, give it a light rub before applying a second coat.
If you’re not used to doing stuff like this, practice first until you’re confident enough to do it without making a mess of it.
View chrisstef's profile
chrisstef
17796 posts in 3241 days
#5 posted 10-28-2013 07:39 PM
Deft high gloss lacquer would be my choice. In a rattle can.
404 - Not Found
#6 posted 10-28-2013 08:24 PM
^I would go with anything that Chrisstef recommends
scrapbmxrider16
#7 posted 10-28-2013 10:55 PM
Went with some Minwax spray poly both for convenience and prince.
crank49
#8 posted 10-29-2013 12:49 AM
I was referring to the metal part.
Of course you would not paint walnut and maple.
Never occurred to me you were asking about finishing the wood part.
