Tenons too loose?
Forum topic by CrazeeTxn posted 10-28-2013 12:31 AM 1182 views 0 times favorited 10 replies Add to Favorites Watch
View CrazeeTxn's profile
CrazeeTxn
151 posts in 1945 days
10-28-2013 12:31 AM
So I’m in the process of building a bed for my son. He wanted a raised panel bed. Gave me a pic and so I’m off to the races…
My problem is, I put the cart before the horse. I cut the tenons on the stiles then didn’t pay attention when I cut the grooves on the rails. Now the stiles are kind of loose. Meaning it’s not a snug fit.
I realized my error before I gut the groove in the legs, so I’m good there. Question is, I’m going to glue the stiles to the rails and the panels will float. Do you think it will be ok, or should I cut more stiles and make them fit snug? I work with rough lumber, so if I need to make more, I’m going to have to work the roughness out :)
As always, the advice is much appreciated.
10 replies so far
View HorizontalMike's profile
HorizontalMike
7755 posts in 2909 days
#1 posted 10-28-2013 01:31 AM
I have had to shim a couple of M/T joints when this happened to me before. If you have thin stock that will already fit then you are good to go. If not, I might suggest widening the groove to fit what thin stock you have or could make.
An alternative would be to glue additional stock to the tenons and re-cut the tenons to fit the existing grooves. Just an idea…
10378 posts in 3643 days
#2 posted 10-28-2013 01:32 AM
Too thin tenons have happened to me plenty. I usually glue
some veneer or thin stock to one or both faces of the tenon
and let it dry, then re-cut the tenon cheeks.
CrazeeTxn
#3 posted 10-28-2013 02:09 AM
First thought was glue up some smaller pieces. But there 16 of them and were only talking less than 1/8”. Might get a roll of veneer tomorrow and see how that works out. Didn’t think about that. Was trying to figure out how I’m gonna plane pieces to 1/16” :-)
#4 posted 10-28-2013 02:15 AM
Oh, just rip a board then move your fence in 1/16” + the
thickness of your saw blade.
View Thalweg's profile
Thalweg
97 posts in 3401 days
#5 posted 10-28-2013 02:18 AM
You might try gluing with polyurethane glue (Gorilla Glue). It’ll expand to fill the joint.
View iminmyshop's profile
iminmyshop
284 posts in 1989 days
#6 posted 10-28-2013 02:33 AM
Usually I just glue on some thin veneer but do so on both sides of the tenon so it is not offset.
Alternatively, you can drill out the tenon and turn it into another mortise. Then use loose tenons. If you go the latter route, I suggest test cutting a mortise on throw-away stock first so you make sure you get the size right.
-- http://www.alansfinewoodworking.com/
View NiteWalker's profile
NiteWalker
2737 posts in 2572 days
#7 posted 10-28-2013 03:16 AM
Depends on how loose.
Using epoxy is an option.
View pintodeluxe's profile
pintodeluxe
5654 posts in 2808 days
#8 posted 10-28-2013 03:25 AM
Look at your design. If the tenons in question are needed for proper structure and support, then they should be shimmed or replaced. If they are largely decorative based on their location, then a little loose might be okay.
For example many of the parts on my panel beds don’t even exist on most beds, so there are plenty of other parts for a solid structure.
View AlaskaGuy's profile
AlaskaGuy
4127 posts in 2304 days
#9 posted 10-28-2013 03:52 AM
+1
CrazeeTxn
#10 posted 10-28-2013 11:30 PM
Not sure if they pieces were structurally needed as the sides are glued into the legs. It was more a piece of mind I reckon.
I carefully cut some thin pieces on the miter saw, glued them up, and presto, instant snuggation.
Thanks for all the replies. Guess I should quit over analying stuff and just go with my gut.
