Table Saw Motor/Pulleys Shudder On Slowdown... Why?
Forum topic by jonah posted 10-26-2013 02:54 AM 2916 views 0 times favorited 23 replies Add to Favorites Watch
View jonah's profile
jonah
1820 posts in 3384 days
10-26-2013 02:54 AM
I have a Ridgid 3650 that has served me well for the last five or so years. Pretty much the whole time I’ve had it, the saw has made a shuddering noise when the belts slow down after I turn it off. The motor runs perfectly well, smoothly and quietly. It cuts fine, doesn’t heat up, doesn’t trip its thermal breaker or anything else.
Why is it shuddering? Is it something to be concerned about? How do I fix it? I don’t have a great deal of experience with induction motors aside from this saw.
23 replies so far
View tefinn's profile
tefinn
1222 posts in 2522 days
#1 posted 10-26-2013 03:01 AM
Does it vibrate at all on start up? Check the belt for wear or set in the belt from sitting too long. Also make sure the pulleys are tight and co-planer to each other. And last of all check the bearings throughout for wear.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
jonah
#2 posted 10-26-2013 03:13 AM
It doesn’t vibrate appreciably on startup, no. When I got the saw, I checked the pulleys and adjusted them to be coplanar. I will check them again when I get some time. I will have to do some disassembly to check into the bearings, so that’ll take a while.
I’m almost positive I replaced the belt when I got the saw, so belt wear probably isn’t a factor, but I might be misremembering. What does belt set look like?
tefinn
#3 posted 10-26-2013 03:25 AM
Belt set is caused by the motor tension on the belt when the tool isn’t used for awhile. The belt “sets” to the shape of the pulleys. This will cause the tool to vibrate on start up and shut down. If it’s bad enough it will even vibrate while running. It usually goes away with a little use, but if the belt is stiff or old it may not go away. A lot of people change to link belts to eliminate this problem. You said you’ve used the saw “five or so years”. If the belt is that old it could be getting stiff, especially if you don’t use it regularly or it’s in non-heated shop.
To check the bearings just spin the shafts (motor and arbor) and check for grinding. Then see if they have up and down play.
jonah
#4 posted 10-26-2013 05:09 PM
Thanks for the explanation. The motor shaft and arbor both spin smoothly with no grinding. I have been meaning to go to a link belt anyway, so maybe I’ll just replace the belt and see if that solves the problem.
View AlanBienlein's profile
AlanBienlein
159 posts in 2760 days
#5 posted 10-26-2013 05:43 PM
You have the same saw I do and it originally came with a serpentine belt which is much better than a link belt. I’ve had this saw since 2005 and am using the same serpentine belt it came with.
Mine use to shutter on shut down like yours until I put a resistor across the terminals of the start capacitor. Then the problem went away. Check to see when it happens. If you notice the shudder right after you hear the centrifugal switch reengage then a resistor across the start cap terminals might be the answer.
View Jim Finn's profile
Jim Finn
2666 posts in 3007 days
#6 posted 10-27-2013 02:29 PM
I have this saw and mine has a serpentine belt and has served me well since 2006. I have done no repairs or changes to this saw and I use it every day.
-- No PHD just a DD214 and a GED Website> https://craftingcouple.com
jonah
#7 posted 10-27-2013 10:21 PM
My saw does not have a serpentine belt, just a normal v-belt. I have never seen a contractor saw with a serpentine belt before, honestly. The manual, parts diagram, and every 3650 I’ve seen all have v-belts.
AlanBienlein
#8 posted 10-28-2013 12:15 AM
Here are a few pics of my TS3650. My wife bought me this saw for Christmas back in 2005 and has seen use ever since then.
View taoist's profile
taoist
124 posts in 2577 days
#9 posted 10-28-2013 12:27 AM
If your belt is the same as in the pictures, it is a ribbed belt.
View yrob's profile
yrob
340 posts in 3738 days
#10 posted 10-28-2013 12:35 AM
Its the belt. I have the same saw and had exactly the same problem. As soon as I replaced it, the vibration disappeared. Regarding, the link belts, It does not work well on a TS3650 because of the peculiar shape of the pulleys. You would have to replace those pulleys with standard cast iron ones that are not ribbed. I did try to use the link belts and they kept jumping off. I just bought a new serpentine belt instead.
-- Yves
18676 posts in 1942 days
#11 posted 10-28-2013 01:22 AM
Someone asked this same question a while back and it was brought up that on power down there can be an electrical anomaly where the still turning motor creates that vibration. Someone else can or may explain it better. I believe knotscott explained it best.
View MarkwithaK's profile
MarkwithaK
370 posts in 3263 days
#12 posted 10-28-2013 01:42 AM
This may seem rather silly but are you certain that there is no wobble on the saw? I saw this because one of the levelers on my 4511 is shy of making contact with the floor and I get the same thing on powering down.
-- If at first you don't succeed then maybe skydiving isn't for you.
View Woodknack's profile
Woodknack
12242 posts in 2465 days
#13 posted 10-28-2013 04:14 AM
A slight shudder when nearing a stop is normal on contractor/hybrids I thought. My Delta has always done it and has machined pulleys. Adding a link belt did help but not stop it completely.
tefinn
#14 posted 10-28-2013 04:39 AM
jonah – The guys are right that the belt on your saw should be a ribbed belt and not a v-belt. Wasn’t thinking, Ridgid uses ribbed belts and you can’t use a link belt. It could still be the belt causing the problem or the motor mounting might need adjusting to take out excess slack. I’m not familiar with the electrical problem firefighterontheside mentioned so I can’t advise on that.
#15 posted 10-28-2013 01:32 PM
I’ll do a search and see if I can find the post I mentioned.
