What did I buy 6 months ago
« back to Coffee Lounge forum
Forum topic by PASs posted 10-25-2013 05:40 AM 932 views 0 times favorited 2 replies Add to Favorites Watch
View PASs's profile
PASs
595 posts in 3332 days
10-25-2013 05:40 AM
Topic tags/keywords: resource tip tools resources
I was playing around learning about UPC codes this morning and then doing the business books this evening when I noticed the numbers on my Home Depot receipt looked like the numbers that the UPC bar codes are based on.
On a whim I went to the Home Depot site and entered a code in the search box.
Sure enough, it pulled up the item.
I don’t know how far back it works, I would assume as long as the item is in stock from the same supplier.
And since I was on a roll on another whim I put “UPC 022000159540” into a bare Google search window.
I’ll let the adventurous of you figure out what it is. Hint, it’s longer lasting (no, it isn’t vulgar.)
Not sure if it works on other sites, but I do more shopping at Home Depot, so it works for me.
-- Pete, "It isn't broken, you just aren't using it right."
2 replies so far
View oldnovice's profile
oldnovice
7378 posts in 3601 days
#1 posted 10-25-2013 06:19 AM
Long lasting gum!
About 25 years ago, or so, I did quite a bit of work with UPC laser scanners and it was very interesting as to how many different codes are readily available and how smart these reader can be to decipher the code type by themselves. I designed a scanner interface for a PLC to sort rolls of carpet in a distribution facility.
View BJODay's profile
BJODay
527 posts in 2177 days
#2 posted 10-25-2013 02:14 PM
The “Yes” album titled “90125”, (my favorite), is the number from the albums UPC.
BJ
