How should I lay out this trim?
Forum topic by noone posted 10-24-2013 01:56 PM 1464 views 0 times favorited 17 replies Add to Favorites Watch
View noone's profile
noone
583 posts in 2300 days
10-24-2013 01:56 PM
I am working on an applied molding project around our house which consists of a upper rail and picture frames and just got to my first question.
How should I handle what is in the pic here?
Do I need to pull out the old baseboard around the stairs and lay in a new piece of baseboard at an angle across the stairs and cut in the top pieces with a compound miter to match the angle of the baseboard?
Is this the way to go? Keep in mind that I would like to also put in a small picture frame in this area as well.
Are there any better ways to handle this?
17 replies so far
18351 posts in 1884 days
#1 posted 10-24-2013 02:10 PM
Do you intend to make your pic frame in that area square or to match the angle of the rail. You may consider running your rail level with the long rail and dead end it into the door casing. Then redo the base trim by the stairs in the same manner, keep it level with the other base. You will have to fill in the space under the base all the way down to the stairs. Then you can make a square pic frame on the short wall. Just what I might do or make it all tie together.
noone
#2 posted 10-24-2013 02:49 PM
The square will need to match the angle of the rail and the baseboard.
I don’t think I can leave the rail at the same level because the rail on the left side of the door continues around the room at 3 feet off the ground. I think it would look strange to have a rail on the right side of the door four feet high, while the left side of the door and rest of the room has a rail that is 3 feet high.
#3 posted 10-24-2013 04:37 PM
No that wouldn’t look good.
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1755 days
#4 posted 10-24-2013 04:53 PM
Like this? Definitely not to scale, but I think you need to turn the corner with your top rail before angling it down. That way you can get the profiles to line up correctly.
View Richforever's profile
Richforever
757 posts in 3747 days
#5 posted 10-24-2013 07:16 PM
One option is to put a little block called a plinth block on the corner. It connects the rails, but by interrupting the curves of the moldings it makes the mind think it belongs there and is OK. I’ve used this when floors and walls are all wacko, and it looks good.
-- Rich, Seattle, WA
View Jim Baldwin's profile
Jim Baldwin
56 posts in 2385 days
#6 posted 10-24-2013 09:11 PM
I like what Kevin has drawn but perhaps you should alter the bottom base to match the upper detail. That would have been more correct as the moldings would then form a trapezoid, as would be correct going up any stairs.
-- Jim Baldwin/jimhbaldwin@gmail.com
View kdc68's profile
kdc68
2658 posts in 2304 days
#7 posted 10-24-2013 09:24 PM
+1 KevinJeffery…...he has solved your dilemma IMO
-- Measure "at least" twice and cut once
View Bogeyguy's profile
Bogeyguy
548 posts in 2095 days
#8 posted 10-24-2013 09:34 PM
Kevin nailed it.
-- Art, Pittsburgh.
View levan's profile
levan
472 posts in 3006 days
#9 posted 10-24-2013 09:54 PM
From the picture it appears like the top molding is deeper- thicker than the casing on the door. You may need to narrow it up all around the room so it dye’s in to the casing properly. I like Kevin’s drawing, you might also consider matching the base.
-- "If you think you can do a thing or think you can't do a thing, you're right". Henry Ford
View realcowtown_eric's profile
realcowtown_eric
609 posts in 1964 days
#10 posted 10-25-2013 05:12 AM
That’s a curved double unequal and possibly variable angle compound angle cut to be sure! If indeed it can be done.
In my pea-brainjust Has to be cut by hand. Gotta read some of the old joinery books and get out some drafting tools to generate the curve on paper. ...you line up the intersections of the moulding details to generate the curve!....No other way! I’d have to go looking for the exact reference, but it’s a common dilemma in Joinery in european houses. A tome titled ” circular joinery” springs to mind, but I cannot remember the author ? Hodgson, Fred
But, to be optimistic, you can mock up the joint and cut and recut until the joint works, then just cut to length on the back lengths….and don’t blow the copes!
Dewalt don’t have a saw for that !!!
If I was paying you, I’d opt for just a return on the main wall portion. If you don’t know how to do the joint, it will take hours to figure it out and finesse it to an acceptable level.
Clearly a joint that if you pull of you can be proud of, and it may NOT be even possible, and if someone else is paying the tab, they will be damned incensed at the cost of making it work.
An interesting conundrum to be sure. Let us know the bottom line.
-- Real_cowtown_eric
noone
#11 posted 10-25-2013 02:32 PM
I think I do like Kevin’s idea. The bonus with his method is that I don’t have to redo that piece on the main wall either.
Question-
In general, for the most part, I have been doing returns at the ends when this molding hits a casing. for the left hand side of this molding where it ends at the casing, should I just do a return at an angle? I’m thinking this compound cut should be possible. I’d like the rail/apron to be square to the casing when it returns.
View tefinn's profile
tefinn
1222 posts in 2464 days
#12 posted 10-25-2013 02:48 PM
I like to do the return like this.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
tefinn
#13 posted 10-25-2013 02:53 PM
This is the better looking, but more complicated way.
noone
#14 posted 10-25-2013 05:29 PM
I do my returns like the first picture as well.
My question was how do I cut a return on an angle?
You know, the more I think about it, maybe I should cut the rail, from right to left, horizontal one inch, angle down, then horizontal one inch. That may look good.
tefinn
#15 posted 10-25-2013 05:49 PM
Sorry, I read the question wrong. What you have figured is the way to do it. Come around at the top with a small straight piece, then angle down. At the bottom, level the angle towards the door with a small piece and end with the return towards the wall.
