Educate me on Poplar
Forum topic by Jofa posted 10-23-2013 10:26 PM 1824 views 0 times favorited 25 replies Add to Favorites Watch
View Jofa's profile
Jofa
272 posts in 1712 days
10-23-2013 10:26 PM
Hey all.
I have a new pedlaboard customer who asked for Poplar as one of the options. He wants a moderate to light stain with a semigloss laquer finish.
My question is regarding how Poplar might handle stain and/or laquer. I believe I read somewhere on LJ’s that Poplar has a tendency to oxidize?? or that it may not stain with predictable results.
I will knock back the stain a little with some steel wool just to get some of the grain to pop but I figured I would ask the experts. Thanks.
-- Thank you Lord for the passion and ability to make things from your creation.
25 replies so far
View TheDane's profile
TheDane
5349 posts in 3537 days
#1 posted 10-23-2013 10:31 PM
In my experience, it is best for paint … with stain, it tends to blotch. I have had success staining it after using Charles Neil’s Blotch Control.
View Anthony's profile
Anthony
122 posts in 1586 days
#2 posted 10-23-2013 10:41 PM
Hey Jofa! As I write this I am applying the first coat of gel stain to a poplar box. I have had good luck staining by using a pre-conditioner prior to the stain. I also use gel stains which, combined with the conditioner, tends to blotch less. I will let you know how the box turns out in a few minutes.
-- Anthony - "The blacksmith and the artist, reflect it in their art. They forge their creativity, closer to the heart"
View Jofa's profile
Jofa
#3 posted 10-23-2013 10:53 PM
Thanks Gerry and Anthony. Definitely let me know how it turns out!
View pintodeluxe's profile
pintodeluxe
5544 posts in 2687 days
#4 posted 10-23-2013 11:02 PM
If I had to stain poplar I would use a washcoat of shellac first. I like a 3:2 ratio of denatured alcohol to Zinssner Bullseye Seal Coat. This ratio seals the wood to prevent blotching, but won’t prevent you from getting darker colors.
I really prefer to use poplar as a secondary wood for drawer boxes. In that case I just spray them with clear shellac, and they are quite attractive.
View bondogaposis's profile
bondogaposis
4529 posts in 2225 days
#5 posted 10-23-2013 11:03 PM
The above advice is right on.
-- Bondo Gaposis
View kdc68's profile
kdc68
2636 posts in 2151 days
#6 posted 10-23-2013 11:07 PM
Relatively inexpensive. Mainly clear and knot free wood that is easy to machine. Great choice of wood for paint. The green heartwood will eventually turn towards a brown color. Staining would require a pre stain conditioner or you can try dyes by itself or a combination of dyes, toners, and glazes. Gel stains and shellac as others mentioned work as well. ..I personally like it with a clear finish…my shop “furniture” is mostly made of poplar with a clear finish….this is my outfeed table
http://lumberjocks.com/projects/89246
-- Measure "at least" twice and cut once
Anthony
#7 posted 10-23-2013 11:12 PM
kdc68, love the outfeed table! Nice Work.
Jofa, the gel stain came out good. I maybe could have let it sit a bit more before wiping it off.
Be wary of sanding, Poplar is very soft and any sanding marks will show if you use a darker stain so surface prep is vitally important.
View Monte Pittman's profile
Monte Pittman
27732 posts in 2212 days
#8 posted 10-23-2013 11:17 PM
I think a sealer or shellac first coat will take care of your problems.
-- Mother Nature created it, I just assemble it.
kdc68
#9 posted 10-23-2013 11:18 PM
Anthony...thanks Jofa...good luck and looking forward to seeing the finished project
View Jofa's profile
Jofa
#10 posted 10-23-2013 11:19 PM
Wow thanks guys.
kdc68, that outfeed table is nicer than my bedroom furniture!
Anthony, thanks for the heads up on the stain.
I know the customer wants something darker than pine and the blotch thing concerns me. I may just look for boards that have some darkness already in them. Either that or look for some other species that will stain better.
kdc68
#11 posted 10-23-2013 11:41 PM
Jofa...thanks…..If you have scrap of different species …make some stain samples…let your customer view each and that may help
View Jofa's profile
Jofa
#12 posted 10-23-2013 11:55 PM
^ yep I’m definitely going to try a couple of pieces for my own edification. As for the customer… Nova Scotia! LOL!!!
View WalterB's profile
WalterB
8 posts in 1555 days
#13 posted 10-24-2013 12:20 AM
I second the suggestion to use Charles Neil’s Blotch Control. It makes a huge difference. As to looking for boards with some darkness, without the blotch control, I think that the lighter wood took darker stain and the darker stayed about the same. I know that sounds backward but that was my observation.
kdc68
#14 posted 10-24-2013 02:26 AM
Jofa...this may be helpful
http://americanwoodworker.com/blogs/techniques/archive/2012/05/24/make-poplar-look-pretty.aspx
View ColonelTravis's profile
ColonelTravis
1725 posts in 1768 days
#15 posted 10-24-2013 02:46 AM
kdc68, that is a nice table and link there. Helpful thread all around.
