How to zero DRO on a planer?
Forum topic by Loren posted 10-23-2013 12:32 AM 1133 views 0 times favorited 8 replies Add to Favorites Watch
View Loren's profile
10477 posts in 3887 days
10-23-2013 12:32 AM
I took my DRO off my drum sander and installed it on my planer.
I can zero it on the drum sander but the planer only goes down
to 1/4” or so.
Is there a way to zero these things to planers or do I have to
work to relative accuracy?
8 replies so far
View cutmantom's profile
cutmantom
407 posts in 3274 days
#1 posted 10-23-2013 12:51 AM
Plane a piece of wood, zero the dro then insert a piece of planed wood between the end of the dro and the machine,not sure about this as I don’t know how your dro is set up
View Handtooler's profile
Handtooler
1628 posts in 2371 days
#2 posted 10-23-2013 12:54 AM
Can you place a known 2” block on the table and raise the table to touch the cutter at its edge then get the Digital Readout to read 2”; then all thinner planed material down to the planners thinest 1/4” should read accurately. Is this correct?
-- Russell Pitner Hixson, TN 37343 bassboy40@outlook.com
#3 posted 10-23-2013 01:17 AM
Yeah, I’m not sure if there’s a way to input “2” into the thing after
it’s zeroed or cleared. That’s the question I guess. I can zero it
at 2” but I don’t know how to then bump the reading up to
2.00”.
Handtooler
#4 posted 10-23-2013 04:03 AM
Then use a 1” block and zero; then you can always subract 1” mentally from its reading and you should be right on. For example 1 will be stock at 5/8” thick. Will this help?
#5 posted 10-23-2013 05:02 AM
That may be what I have to do.
5240 posts in 2733 days
#6 posted 10-23-2013 12:43 PM
I’ve got a Wixey on mine and the method cutmantom described is what I do.
View PaulDoug's profile
PaulDoug
1724 posts in 1943 days
#7 posted 10-23-2013 01:39 PM
You might go to the Wixey site and look at the online manual for one of their planer gauges. It may apply for mounting and calibrating the one you have.
View SASmith               's profile
SASmith
1850 posts in 3226 days
#8 posted 10-23-2013 11:03 PM
This thread discusses an install that is capable of being zeroed.
-- Scott Smith, Southern Illinois
