Painting PVC pipe
Forum topic by Betsy posted 11-29-2008 06:09 PM 5159 views 1 time favorited 10 replies Add to Favorites Watch
View Betsy's profile
Betsy
3391 posts in 3861 days
11-29-2008 06:09 PM
Will PVC pipe take an enamel paint without chipping off before Christmas morning is over?
Thanks
-- "Our past judges our present." JFK - 1962; American Heritage Magazine
10 replies so far
View Quixote's profile
Quixote
206 posts in 3603 days
#1 posted 11-29-2008 06:20 PM
Yes.
Scuff the surface first with a scuff pad, steel wool, fine sandpaper or some abrasive scouring powder to provide some mechanical adhesion.
Final rinse with a vinegar solution ( for the mild acidic wash), and you should be ok for a short term project.
Q
-- I don't make sawdust...I produce vast quantities of "Micro Mulch."
Betsy
#2 posted 11-29-2008 06:26 PM
Terrific. Thanks Q!
View motthunter's profile
motthunter
2141 posts in 3764 days
#3 posted 11-29-2008 06:31 PM
Scuff and use gripper primer first.. It will bond well and hten you can paint as you like. i have used gripper on ceramic successfully too.
-- making sawdust....
View John Gray's profile
John Gray
2370 posts in 3850 days
#4 posted 11-29-2008 06:39 PM
You might check with Rustoleum they make some paints specifically for plastics they might work on PCV, I’ve used it and it’s worked good for me. I used it on lawn chairs and it really stays on.
View lew's profile
lew
12017 posts in 3720 days
#5 posted 11-29-2008 07:35 PM
Betsy,
I have sprayed thinned, water based exterior house paint on plastic spoutings/gutters. Holds up pretty well. I did wash it down with vinegar and water solution first.
Lew
View angelis's profile
angelis
54 posts in 3873 days
#6 posted 12-01-2008 04:49 PM
For the best results use a scuff the surface and use a plastic paint primer. Most places carry the primers in spray cans as well.
View Kindlingmaker's profile
Kindlingmaker
2656 posts in 3491 days
#7 posted 12-01-2008 06:08 PM
I use an epoxy chormate primer then any paint will hold fast to it.
View sry's profile
sry
147 posts in 3573 days
#8 posted 12-01-2008 06:37 PM
I’ve used that rustoleum paint specially formulated for plastic on a PVC coat tree I built about 4 years ago, and it’s still hanging on beautifully
Scuff the surface first of course
Betsy
#9 posted 12-01-2008 08:56 PM
Thanks guys. I appreciate the tips.
View HokieMojo's profile
HokieMojo
2104 posts in 3693 days
#10 posted 12-02-2008 12:37 AM
When I was modding a desktop computer, I was painting some of the plastic. Unless you are trying to use materials you already own, you may want to check out the autoparts store. There are products called “vinyl dyes”. They cost the same as a can of spray paint and work just the same. It sticks great. If you want, I can see about posting a picture later. Just PM me if you want to see it and I’ll try to post it here. Any clues as to what you are trying to make?
