Fitting a Shelf to an Uneven Wall
Forum topic by lew posted 11-29-2008 04:58 PM 22529 views 0 times favorited 10 replies Add to Favorites Watch
View lew's profile
lew
12102 posts in 3779 days
11-29-2008 04:58 PM
Topic tags/keywords: question scribe to a wall shelves help
I’ve run into a bit of a problem and hoping maybe someone can offer a suggestion.
I know how to scribe a cabinet or shelf to an uneven wall. My problem is the shelves are “corner” floating shelves. Although this is a brand new home, the corner is not square and the drywallers left a “hollow” between both outside corners and the 90 degree corner. If I scribe the shelf to the first wall, then the opposite side is no longer correct and visa versa. It appears to be a vicious circle, with the shelf getting smaller with each correction.
The client does not want any trim molding along the walls to detract from the floating “look” so this has to pretty close to a perfect fit. Any suggestion, ideas and comments are welcome!
Thanks!!
Lew
10 replies so far
View Les Hastings's profile
Les Hastings
1305 posts in 3797 days
#1 posted 11-29-2008 05:25 PM
Take two pieces of 1/4 mdf or ply. Use one for each side, scribe and fit both to one side of the wall, then use them as templates for each side of your shelf. If the corner is out of square pin the two pieces together with a cross piece at the correct angle. Should solve the problem.
-- Les, Wichita, Ks. (I'd rather be covered in saw dust!)
View lew's profile
lew
#2 posted 11-29-2008 05:42 PM
Thanks!!!!!
Now that you explained it, the problem seems so simple. Wish I was not so much a one dimensional thinker!
Lew
View motthunter's profile
motthunter
2141 posts in 3823 days
#3 posted 11-29-2008 06:33 PM
I would make a cardboard template.. this works well too.. you also can use hot glue and shim stock to mock it up like countertop guys do
-- making sawdust....
View lew's profile
lew
#4 posted 11-29-2008 07:31 PM
I made the one like the counter top guys do but then when I started to form it into shape I realized the problem.
I am going to try what Les suggested- making each side fit first- then make get the correct corner angle. Cardboard might be the best material to use because the shelves are only a little over 24” on each side and cutting and fitting the template would sure be easier- especially in the clients house.
Thanks for the ideas!
Lew
View mmh's profile
mmh
3677 posts in 3746 days
#5 posted 11-29-2008 08:55 PM
Suggestion #1: Re-dry wall the wall.
Suggestion #2: Install as is, Offer client a nice hard drink.
Suggestion #3: Dim lights.
View lew's profile
lew
#6 posted 11-29-2008 09:10 PM
mmh,
I like those suggestions. I think I’ll change the order-
Carpenter takes nice hard drink
Dim lights
Take another hard drink
Give client shelf and let him put it up.
View dustygirl's profile
dustygirl
862 posts in 3752 days
#7 posted 11-29-2008 10:59 PM
Lew you sound like one of the contractors that showed up at my last place.(LOL)
View Roper's profile
Roper
1389 posts in 3737 days
#8 posted 11-29-2008 11:24 PM
option 4 hire a painter that goes heavy on the caulk.
-- Roper - Master of sawdust- www.roperwoodturning.com
View romansfivefive's profile
romansfivefive
302 posts in 3797 days
#9 posted 11-30-2008 01:55 AM
I am sure there is some sort of tool you should buy to do that job… even if you can just do it with cardboard.
-- The CNC machine can either produce the work of art you imagined, or very decorative firewood.
View AitchKay's profile
AitchKay
2 posts in 3516 days
#10 posted 12-04-2008 05:26 PM
Usually you scribe perpendicular to the surface. But the real rule is scribe in the direction you need to move. In this case you need to scribe at a 45 angle to both walls, because you want to push your shelves in tight to the corner.
So set your pencil compass to the largest gap, set its fixed leg into the very inside corner of the wall, with the pencil leg sticking out at a 45 angle. Then mark both legs of the shelf.
If you start in the corner you should be able to eyeball the angle, but you can also make a few light reference lines—before you hold it to the wall, use your combination square to gauge these off of both wall legs. The reference lines will all be parallel, with one of them landing on the “miter” line of the inside corner.
Then hold the shelf to the wall, and scribe, making sure that both legs of the compass cross each refence line at exactly the same time.
As usual, this takes more time t describe than to do!
AitchKay
