My table saw is tapering cuts.
Forum topic by agallant posted 10-22-2013 01:55 PM 1263 views 0 times favorited 16 replies Add to Favorites Watch
View agallant's profile
agallant
551 posts in 2880 days
10-22-2013 01:55 PM
My table saw is tapering cuts. It I cut something say 2 feet long it will be about 1/32 thinner at the end of the cut. Is this an alignment issue?
16 replies so far
View UpstateNYdude's profile
UpstateNYdude
916 posts in 1976 days
#1 posted 10-22-2013 01:58 PM
make sure the arbor nut is flat and your fence is parallel to the blade
-- Nick, “I am always doing what I cannot do yet, in order to learn how to do it.” – Vincent Van Gogh
agallant
#2 posted 10-22-2013 01:59 PM
I don’t know why but I am really bad at trying to figure out how to align the fence.
View Earlextech's profile
Earlextech
1161 posts in 2684 days
#3 posted 10-22-2013 02:07 PM
Align the fence to the t-slot
View Grandpa's profile
Grandpa
3259 posts in 2668 days
#4 posted 10-22-2013 09:28 PM
align everything to the T-slot.
View lieutenantdan's profile
lieutenantdan
176 posts in 2299 days
#5 posted 10-22-2013 10:48 PM
Buy a new table saw. :)
-- "Of all the things I have lost in life, I miss my mind the most."
18145 posts in 1850 days
#6 posted 10-22-2013 11:30 PM
What kind of fence do you have? A bad one might be pushed out of parallel at the end of cut.
#7 posted 10-22-2013 11:32 PM
View JonHitThingWithRock's profile
JonHitThingWithRock
97 posts in 1715 days
#8 posted 10-22-2013 11:53 PM
the wood whisperer has a good video from a few years ago (i think) that goes over how to calibrate a table saw. Also, if you can find it, norm did a quick alignment check in the table saw special of the new yankee workshop. essentially the idea is to first get the front and back of your saw blade perfectly aligned with the miter slot, once that’s done, check the front and back of your fence against the same miter slot to make sure it’s in exact parellel with it.
One other thing, I had bad bearings on my saw some years back, and nothing came out straight or square despite hours of tuning, the vibration just moved things around too much, once i replaced those, everything was perfect. So if your saw is vibrating a lot or sounds like marbles rolling around in a coffee can, it might be worth checking into.
These are the wood whisperer videos
http://www.thewoodwhisperer.com/videos/tablesaw-setup-tuneup-pt-1/
http://www.thewoodwhisperer.com/videos/tablesaw-setup-tuneup-pt-2/
View DS's profile
DS
2916 posts in 2413 days
#9 posted 10-23-2013 12:02 AM
I saw your Subject line and thought—Cool, he didn’t even have to build a jig.
+1 for aligning the blade to the table, the table to the fence, etc.
Sometimes the splitter is out of alignment and it pulls my material to one side…
agallant
#10 posted 10-23-2013 01:00 AM
Its a 3hp unisaw with birdsmyer fence
View JustJoe's profile
JustJoe
1554 posts in 2031 days
#11 posted 10-23-2013 01:14 AM
That could be the problem. Did you by any chance buy this fence from the same guy who sold you the Roleks watch, the guchi purse and the Nyke sneakers? :)
It sounds like some alignment is off a bit.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
agallant
#12 posted 10-23-2013 01:18 AM
Yeah I know I cant spell :)
View gfadvm's profile
gfadvm
14940 posts in 2683 days
#13 posted 10-23-2013 01:23 AM
Joe, You’ve done it again! Now I have to clean the coffee off my keyboard!
UpstateNYdude
#14 posted 10-23-2013 05:24 PM
Sorry ignore my comment about the blade I meant T-slot was a long ass day yesterday…
View MrRon's profile
MrRon
4757 posts in 3236 days
#15 posted 10-23-2013 06:50 PM
First align the blade to the miter slot; then align the fence to the miter slot. To align the blade, all you need is a combination square. Set the head of the square against the side, closest to the blade of the miter slot. Slide the square blade so it touches a tooth on the saw blade at the front of the blade. mark that tooth with a magic marker. move the square to the rear of the blade and rotate the saw blade so the same tooth touches the end of the square. If they don’t line up, you will have to loosen the bolts that holds the top to the cabinet and adjust until the blade to slot are the same.
To align the fence, use the same combination square and test it at the front of the fence and at the end of the fence. Adjustments can be made by turning over the fence and adjusting the two set screws. I don’t have a unisaw, but someone else here can walk you through the alignment steps.
CAUTION: Make sure the saw is unplugged before doing anything.
