How do I dress a grinding wheel that is way out of round?
Forum topic by Rob Drown posted 10-22-2013 07:45 AM 4148 views 0 times favorited 10 replies Add to Favorites Watch
View Rob Drown's profile
Rob Drown
790 posts in 3950 days
10-22-2013 07:45 AM
Topic tags/keywords: question wet grinder
I have a low speed delta wet grinding wheel that is about 1/8 ” out of round. I want to use sharpening jigs with it. How do I true this wheel? Will a diamond dresser take off that much material with out wearing out?
-- The expectations of life depend upon diligence; the mechanic that would perfect his work must first sharpen his tools. Confucius, 经过艰苦的努力的梦想可以成真
10 replies so far
View stefang's profile
stefang
15881 posts in 3451 days
#1 posted 10-22-2013 09:40 AM
That might depend on it’s diameter Rob. I buy my diamond dressers pretty cheap over here and if I wore one out, it wouldn’t be a big deal to replace it compared to the cost of a new grinding wheel.
View kaerlighedsbamsen's profile
kaerlighedsbamsen
1250 posts in 1831 days
#2 posted 10-22-2013 10:06 AM
The cheap&dirty way is to just use a coarse grinding disc in a angle grinder, support it on the toolrest and some wood and grind away. Works surprisingly well.
But if your wheel is that much off chances are that it is poorly made and have uneven density in the grain and bonding material and the wheel wil be off again quick. A new wheel is perhaps a better solution. Scheppach sells some blue ones that are reasonable prized and works great (if your grinder is the Tormek-type)
-- "Do or Do not. There is no try." - Yoda
View Bluepine38's profile
Bluepine38
3379 posts in 3202 days
#3 posted 10-22-2013 03:41 PM
Stefang’s diamond dressing idea will work, but if it is that much out of round kaer’s will be faster, just wear a
good dust mask and eye protection. If it is the same as my Delta it has a container to hold the water that
the wheel sets in. Do not use the water holder, the furnished grinding wheel soaks up too much water, and
will soften and get out of round again. I just use a spray bottle and keep the wheel moist enough to grind easy. A star type dressing wheel will remove the glaze caused by grinding to let the wheel cut better.
Rob Drown
#4 posted 10-22-2013 04:58 PM
Mke, kaerlighedsbamsen, and Gus. Thank you very Much. This grinder has been sitting on the shelf, now pretty soon it is going to work!!!! It is the soaking that makes it go out of round!!
kaerlighedsbamsen
#5 posted 10-22-2013 05:59 PM
The wheel is not supposed to sit in the water all the time. Does the design allow to lower the water container? Otherwise i think Blue´s adwise sounds good.
View SCOTSMAN's profile
SCOTSMAN
5849 posts in 3702 days
#6 posted 10-22-2013 07:27 PM
A good diamond grinder get a flat one shaped like a letter T and not a single point for best results.Alistair
View Clint Searl's profile
Clint Searl
1533 posts in 2478 days
#7 posted 10-22-2013 08:13 PM
Trying to fix it ain’t worth the aggravation, just buy a new wheel.
Bluepine38
#8 posted 10-23-2013 02:16 PM
Clint if it is the wheel I think it is, the cost runs from $94. to $400. That is worth a little aggravation.
View DrDirt's profile
DrDirt
4451 posts in 3859 days
#9 posted 10-23-2013 04:22 PM
Good thoughts on the dressing
I would start by checking the grinder shaft and make sure the bushing in the wheel is intact.
I have never seen a modern wheel 1/8th out of round.
The wheels on my sharperner have oneway balancing hubs on them.
But I have a variable speed grinder not just slow speed sharpening.
Rob Drown
#10 posted 10-23-2013 09:15 PM
Im going to give truing a go and the just use a little water spray to keep things lubricated and cool. Thank you all!!
