Screw-ups waiting to happen... and how to prevent them.
Forum topic by 404 - Not Found posted 10-21-2013 10:35 PM 1408 views 0 times favorited 25 replies Add to Favorites Watch
404 - Not Found
2544 posts in 2996 days
10-21-2013 10:35 PM
For every type of operation in the shop, no matter how simple or complex, there’s a way to screw it up. I’m not talking operator error, like cutting the wrong side of the line, gluing something out of square – or sanding through a veneer. There are screw-ups that you don’t even know about until you’ve, well, screwed it up.
Here are three examples, things I’m especially wary of – having experienced them at first hand.
Glob of glue on vice cheeks leaving unwanted indentations on your workpiece.
Fine height adjuster on router unwinding in use – means you’ve unwittingly been routing progressively deeper and the only right piece is the first piece. (Similarly router collet not tight enough allowing bit to pull out on you)
The piece of paper put between the clamp and the work piece to prevent iron marks on your glue up – gets scrunched up between the boards when you tighten the clamps and is glued into the top or panel forever.
These are things I am extra vigilant about, but is there anything in particular you are extra wary of in your woodworking quests?
25 replies so far
View GOOD LUCK TO ALL's profile
GOOD LUCK TO ALL
418 posts in 1754 days
#1 posted 10-21-2013 10:55 PM
I keep everything good side up as I’m milling pcs parts. I hate it when I turn a pc upside down and get the chip out, or the bad side to the inside or on the joint instead of a good clean joint.
Face up for everything all the way up to the build.
View Moron's profile
Moron
5032 posts in 3920 days
#2 posted 10-21-2013 11:26 PM
avoid working with “greenhorns” : ))
sadly it is most often unavoidable : (
18351 posts in 1883 days
#3 posted 10-22-2013 12:55 AM
I always draw up plans for my projects and make calculations, but I really only follow them in the beginning of the project. I feel it gets me started in the right direction and then from there, I measure as I go and design as I go. So my thing is following plans originally, but then letting the rest of the design evolve as I go. This is one reason I don’t like to build from premade plans. I have a hard time following them through to the end.
View distrbd's profile
distrbd
2252 posts in 2473 days
#4 posted 10-22-2013 01:03 AM
I measure 5 times before I cut,mainly because the tape measure I’m using(Lufkin) is not very easy to read .
-- Ken from Ontario, Canada
View oldnovice's profile
oldnovice
6900 posts in 3394 days
#5 posted 10-22-2013 05:19 AM
Here are some of my worst fears:
  1. Cutting on the wrong side of the TS blade … one kerf off is always to short/narrow.
  2. Applying glue to the wrong face!
  3. Breaking off a screw deep in a hole because the pilot hole is too small.
  4. Drilling a hole too large/too deep
I watch carefully when I do these operation … very carefully!
View pintodeluxe's profile
pintodeluxe
5706 posts in 2840 days
#6 posted 10-22-2013 05:26 AM
I like test fitting everything before glueups. It would be a nightmare to have wet glue on parts that don’t fit.
also
- tearout on a nice big panel.
- forgetting to scrape glue while it’s still soft.
- changing to the dado blade, only to realize you needed the ripping blade first. Arrghh.
View oldmanmxs's profile
oldmanmxs
15 posts in 1783 days
#7 posted 10-22-2013 06:08 AM
Here are some of my issues:
Thinking I have the needed bit or blade and finding after I’ve started that now I need to go purchase it (usually happens at the end of the month and I have to wait to get money to finish the project)
Setting out multiple pieces of wood for a project and at the end realizing I cut the wrong piece and now what I have will not work to finish the project.
Finding a piece of paper or taped that escaped earlier inspection and is now clear coated into the project.
View Blackie_'s profile
Blackie_
4883 posts in 2539 days
#8 posted 10-22-2013 10:19 AM
A glue up mistake is not always a permanent issue.
Depending on how large the project and glue up is, a glue up is not always permanent, it can be delaminated, by using a heat gun of 400 degrees or hotter and heating up the glue joint, (no matter how long cured) and using a metal scrapper working it between the glue joints along with heat it can be split apart with no damage to the wood only a little sanding to remove the glue left behind, any wood glue.
One of my peeves is not getting accurate box joints because not having the proper pin or project placement before making the cut.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View MrRon's profile
MrRon
4795 posts in 3270 days
#9 posted 10-23-2013 06:03 PM
A big screw-up is when you are setting the dado blade height on a table saw. You crank up the blade to find it is too high, so you crank it down a bit. When you do this, you introduce backlash in the blade elevating mechanism. When you run the saw, vibration will cause the blade to drop down a fraction; you end up with a dado that is not deep enough. This also happens with any blade. Always make final height adjustments while cranking UP, never down. The same goes for routers in a table. If you tilt the blade, make sure you return it to zero right after the cuts are made. I hate it when you cut a piece and find that you forget to zero the blade.
MrRon
#10 posted 10-23-2013 06:16 PM
I am a great advocate for precision. My saw is set so that I’m always within .002” of my measurement. I know that kind of accuracy is hard to maintain in wood, but the fact is, the machine is capable of such accuracy and it’s the wood that changes; especially in soft woods. Whatever I’m making, I always make a test cut on scrap before commiting to the actual cut. An inexpensive digital caliper will give you all the precision you will ever need. I do all my woodworking the same as metalworking. Any changes in dimensions due to shrinkage or expansion, are much smaller.
I also draw all my projects with Autocad software. This gives me exact dimensions, eliminating any errors in math.
View teejk's profile
teejk
1215 posts in 2711 days
#11 posted 10-23-2013 06:57 PM
Planning ahead. Like how to attach cleats on a narrow table or box that will not work with your cordless drill driver.
Not related to wood but I watched my HVAC guys install ducting. They have been doing it for decades yet still installed the returns in front of the supply, causing them to have to reach across the former to install the latter. I just shook my head.
GOOD LUCK TO ALL
#12 posted 10-23-2013 07:10 PM
How about building to big to get through the door…Done that before, learned the hard way.
View WayneC's profile
WayneC
13754 posts in 4124 days
#13 posted 10-23-2013 07:16 PM
Reminds me. How did Gibs get his boat out of the basement?
View DaddyZ's profile
DaddyZ
2475 posts in 3067 days
#14 posted 10-23-2013 07:21 PM
Getting out to the shop, only to realize you left the keys to the door Inside the house.
View Earlextech's profile
Earlextech
1162 posts in 2717 days
#15 posted 10-23-2013 07:24 PM
Screw-ups reminds me of a cabinet installer I was working with years ago. We always used 2” screws to attach countertops to bases. This young man grabbed a 2 1/2” and put it through the mica top and well into his palm as he held the top down. He promptly dropped the screw gun and couldn’t remove himself from the top, it became my job to unscrew him and drive to the emergency room.
