$400 Delta 14 in. Band Saw...worth it?
Forum topic by bbc557ci posted 10-21-2013 09:58 PM 1075 views 0 times favorited 5 replies Add to Favorites Watch
View bbc557ci's profile
bbc557ci
595 posts in 2072 days
10-21-2013 09:58 PM
http://syracuse.craigslist.org/tls/4090089814.html
This Delta BS has been on CR for a while now. I actually saw it in person while I was at the sellers house a couple of weeks ago buying a 70 ft. length of no. 8 elec. wire. At the time the seller said she was asking $650 for the saw, which I thought was way too much, so I walked away. Is it worth $400.00 with the speed control and Baldor motor? Another thing, the add says it’s for cutting metal? Looks like a wood cutter to me. Am I out to lunch??
Thanks in advance.
-- Bill, central NY...no where near the "big apple"
5 replies so far
View cabmaker's profile
cabmaker
1730 posts in 2807 days
#1 posted 10-21-2013 10:03 PM
That sounds like reasonable market value for the saw with speed control capabilities.
Need more info.
What model year
And the motor alone would cost you 70% of the asking price
View Quanter50's profile
Quanter50
278 posts in 2294 days
#2 posted 10-21-2013 10:28 PM
I would grab it before someone else does. If it were closer to me, it would be in my basement already.
View JustJoe's profile
JustJoe
1554 posts in 2036 days
#3 posted 10-21-2013 11:19 PM
Way too slow for wood, but for a bandsaw converted to cut metal it’s a steal for that motor with a speed control.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
View Jofa's profile
Jofa
272 posts in 1836 days
#4 posted 10-21-2013 11:41 PM
^ JustJoe, is it simply a matter of converting the diameter of the belt ring thingy?
-- Thank you Lord for the passion and ability to make things from your creation.
JustJoe
#5 posted 10-21-2013 11:47 PM
I believe the correct technical term is ”the round thingamajig”
Yes, changing to a much much much much larger pulley on the motor end, or a much much much much much much smaller pulley on the bandsaw would do the trick. Right now the top speed is 400fpm. You want around 3,000 fpm for wood. You’ll have to look up the whole math bit but you need to go big enough to go about 7.5x faster than it is now. That might be a bigger pulley than you have room for.
