Making a flat fence for sled
Forum topic by boroughdan posted 10-21-2013 08:50 PM 916 views 0 times favorited 4 replies Add to Favorites Watch
View boroughdan's profile
22 posts in 1872 days
10-21-2013 08:50 PM
I need to make a new sled. Mine was slapped together with scrap but has done pretty well. I have been cutting wider pieces and noticing it isnt square enough.
The question I have is how to make the fence. Solid wood seems no good so i am thinking plywood is the way to go. But in most videos I have seen it seems like people just assumbe their plywood is flat. I saw one where william ng glued up two or three pieces on a flat surface to ensure flatness. This is what I will be doing I suppose, though my jointer bed is only about two feet long. Im wondering if there are any other solutions. i want to make the sled as dead on as I can.
Also, plywood or mdf for the base?
View cabmaker's profile
1706 posts in 2739 days
#1 posted 10-21-2013 09:46 PM
3/4 ply for base on mine.
Hardwood for rails
Hardwood for guide rails
#2 posted 10-21-2013 09:48 PM
you dont worry about movement in your fence?
#3 posted 10-21-2013 09:57 PM
No, but if it does occur its easy enough to correct it.
View sixstring's profile
296 posts in 2173 days
#4 posted 10-21-2013 10:17 PM
I used 5/8” Melamine for both of my sled bases. It’s lighter and smoother to push than ply but just as flat if not flatter. My larger one happens to have a solid 2×5 piece of doug fir but it’s what I had on hand at the time and I used my jointer to make it flat. Either material is fine, My smaller one uses (2) pieces of 3/4” plywood and (1) piece of melamine (face) laminated together. My rails are solid maple and solid oak.
Lots of videos on this but it’s simple… Use a good square to make sure the fence is square to the blade. Clamp it down then screw into the runners from the top. That’s what I did and it’s pretty darn straight for everything I do. A tip though… first make sure the blade is square to your mitre slots first!
-- JC Garcia, Concord, CA : "It's easier to ask forgiveness than permission..."
