Ryobi Belt and Disc Sander with 4"x36" belt and 6" wheel (DEAD, and dont know why)
Forum topic by David Milton posted 10-20-2013 05:12 PM 2345 views 0 times favorited 11 replies Add to Favorites Watch
View David Milton's profile
David Milton
29 posts in 1580 days
10-20-2013 05:12 PM
Topic tags/keywords: ryobi table sander belt and disc sander malfunction wont turn on how to fix my sander
i bought a ryobi belt and disc sander about a month ago. it worked fine, and did a really fantastic job. however, last night, when i was just about finished with a nice piece of curly maple burl, i was ready to put the finishing shaping on it with the belt and disc sander. i flipped the switch, and it made a popping sound, and died. anyone have any idea how i might fix this? im not sure if it takes a fuse that i can replace, or if i need to replace the entire motor, or what.
-- David Milton colville washington norwoodorigins@gmail.com
11 replies so far
View Loco's profile
Loco
210 posts in 1623 days
#1 posted 10-20-2013 05:28 PM
Often that crap uses a fusible link ( thin wire that burns first). If it’s beyond warranty, take it apart and look for a flat shaped wire missing the middle section. The really sad ending is where to take it for repair ???. Maybe a computer repair or appliance guy. Usually they just get tossed out.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
View JustJoe's profile
JustJoe
1554 posts in 1912 days
#2 posted 10-20-2013 05:45 PM
1-800-525-2579
www.ryobitools.com
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
David Milton
#3 posted 10-20-2013 09:18 PM
i pulled the power switch out (as advised by www.ryobitools.com customer support) and when i undid the plastic clips that mount the starter relay to the switch the two little metal connector pieces came out. now i can figure out how to put them back in, and ryobi customer service is no help. any light to shed on this subject?
David Milton
#4 posted 10-21-2013 09:10 PM
cant figure out how to put them back in
JustJoe
#5 posted 10-21-2013 09:13 PM
Do you have a pic? Or a diagram of the switch?
My cr@psman 6×48 sander blew the switch last year and when I disassembled it for replacement I don’t remember seeing “two little metal connector pieces.” I did have one little metal strip, that had broken off another little metal strip, and that was the reason the switch was dead.
David Milton
#6 posted 10-26-2013 06:02 AM
i figured it out. after all the asking around via internet, and phone calls, all it took was looking at it in the orange glow of the sunset. for some reason the color of the light made it where i could see how the whole thing went together. haha. thanks for the input though.
View Jim Finn's profile
Jim Finn
2595 posts in 2795 days
#7 posted 10-27-2013 02:40 PM
So is this tool running again?.......... I bought one of these in 2003 and used it a LOT. I was given another just like it that kept throwing belts so I consulted the manual and diagram and the drawing was in error so I applied some common sense to the belt installation and fixed the problem. I used these two sanders for years before upgrading to a 6” belt sander. I sold the 4” sanders to a friend and he still uses them…............... Some call this sander “crap” but I had very good service from mine.
View papabear's profile
papabear
87 posts in 3219 days
#8 posted 10-27-2013 03:05 PM
Mine kept shredding the belts. I thought the first was faulty so bought two replacements. Put the first on and checked the adjustments as best I could and after half a dozen uses it shredded the second one. Took a closer look and tried to re-align the geared pulleys, put the third on and it shredded after about a week.
Gave up on that, went to princess auto, bought two smooth pulleys about the same size as the other, went to Lee-Valley and bought a couple of feet of the adjustable linking drive belt, assembled it all and it has worked great ever since.
I agree with Jim Finn, yes it was inexpensive but you know, I am not a professional and use it for hobby type things and it is perfectly fine. I bought their band saw and drill press with the sander as a package and all work well for what I use them for.
-- Do not meddle in the affairs of dragons for you are crunchy and taste good with ketchup.
View Blackie_'s profile
Blackie_
4843 posts in 2386 days
#9 posted 10-27-2013 06:22 PM
It’s getting to the point where HF machinery is better then Ryobi, I’ve had more faults with my ryobi equipment then any other of my machines, I’m slowly weeding them all out still have a few more to go, as the break I just replace them with better equipment.
I’m assuming David it’s back up and working, I was wondering if it has brushes that could quite possibly go bad.
-- Randy - If I'm not on LJ's then I'm making Saw Dust. Please feel free to visit my store location at http://www.facebook.com/randy.blackstock.custom.wood.designs
View InsideTheBox's profile
InsideTheBox
107 posts in 1547 days
#10 posted 10-28-2013 05:45 AM
Wait, whaat—- I JUST BOUGHT one of those Ryobis tonight and haven’t even gotten it out of the box yet. Are you all saying it’s crap and I should take it back? Or maybe just rejoice that I got the extended warranty?
-- There's no such thing as a mistake; only a quick change of plans.
View rpeeters18's profile
rpeeters18
1 post in 1349 days
#11 posted 05-11-2014 09:51 PM
hi,
i bought the ryobi belt and disc sander 1 day ago, and i suspect here is something wrong. i used it for about 6 hours and it worked perfectly. then with all the dust around the machine, i moved the belt into vertical position, took the belt off and dusted it clean. when i put it back to its original position, and turned it on, it ran fine but as i started to place an object to sand on the belt, the machine started to vibrate. its a rattling kind of sound that does not sound too good for the machine at all. has anyone else had a similar problem and how would i proceed to fix this?
