| Forum topic by Nick Solimine | posted 365 days ago | 1670 views | 0 times favorited | 12 replies | ![]() |
365 days ago |
Topic tags/keywords: tablesaw I own a craftsman 10” table saw #22124 (the zip code saw). -- Nick , North Carolina |
365 days ago |
I saw an article in one of the woodworking magazines recently about making your own. Maybe someone can remember the magazine and which issue it was. -- Charlie M. "Woodworking - patience = firewood" |
365 days ago |
I have seen people make zero clearance inserts with a riving knife built in. This would work fine for the majority of through cuts you make. Obviously it would be in the way if you weren’t cutting completely through the wood. -- Rich in Richmond |
365 days ago |
I think I saw some splitter inserts for a zero clearance in Woodcraft or Rockler (can’t remember which). Make the zero insert out of Masonite or mdf and drill 2 small holes behind the blade and slip the splitter in the holes. Look to be about an inch high and an inch and a half long. -- Gary, South Central Wisconsin. So much to learn, so little time! |
365 days ago |
It was also shown as a Woodworking tip. This version has you sliding a thin wedge in a slot behind the blade. Here’s where you can find it. http://www.woodworkingtips.com/etips/etip060900ws.html -- Gary, South Central Wisconsin. So much to learn, so little time! |
365 days ago |
The November issue of Popular Woodworking had an article by Marc Adams on Kickback. -- Rich, Seattle, WA |
365 days ago |
Hi Nick When you are saying that you removed the “Blade protector”....I’m a little bit confused… Normally, one unit contains 3 parts; Correct me if I’m wrong but, I think that they come as one unit and – as I understand – you removed all the unit… As for Riving Knife (RK)....the RK does the same thing like the splitter but with a small (but big) difference… To visualize it, raise the blade to it’s maximum height…at this position, the splitter will be very close to the blade and will follow the blade contour….now, “weld” the splitter to the blade and, lower the blade…the splitter will go down with the blade and will remain at the same distance and reference to the blade…that’s a Riving Knife… The RK is set to 3~8mm (1/8”~5/16”) from the blade and, ones the distance is set, the RK will stay at the same distance at any blade height and angle. The problem is that the splitter has fixed position and height and when the blade is lowered, the distance of the splitter to the blade will increase and in very low blade positions, the splitter will be quite far from the blade and the “anti-kickback protection” will decrease. As I know, all the “new designs” from 2008 must come with a riving knife but if your saw is 2007 or before design (model), it will not include RK (and that’s – maybe – the reason that Sears “looked at me like i had 2 heads”....simply, there is no RK for this model. You cannot just put a RK on any table saw because it involves some linkage and different design…that’s why the new designs with the RK costs a little bit more… So, the only way that you can go is a splitter as it was suggested on the previous posts. As for the kickback that you got, it’s not necessary because you did not use the splitter….in a perfect world, you should not get a kickback even without using a splitter…. I would check the blade / rip fence alignment…if the fence is “toed-in” at the far side, you might get a kickback even with splitter/RK… Another type of kickback is what I call “Operator induced kickback”....when you are ripping, keep you eyes on the fence and keep the workpiece tight to the fence and don’t let it go till the workpiece is out of the blade back teeth. niki |
365 days ago |
I make my own 90 degree versions by following these instructions. They can be made to varying heights to match common blade heights. I’ve been using them for at least 10 years with terrific results. I’ve also used MicroJig and my General 650’s stock splitter / guard assembly and prefer the shop made version. Mind the grain direction on the splitter, as it matters. -- - Please help keep Lumberjocks an enjoyable escape by refusing to participate in political discussions. Simply spit out the bait and ignore the thread... |
364 days ago |
From all of the reading I’ve done on this subject You cannot add a riving knife to a saw made without one and you won’t be able to in the future. Obviously spliters can be add in many ways as indicated above. Part of the confusion stems from the fact that many manufactures have started using the term riving knife/spliter. if you google “riving knife (without the quotes) you can learn more than you want to know and will probably be even more confused. -- RTB. "dumb animals are not stupid they simply can't talk " |
364 days ago |
A splitter is usually attached to the back of the saw and it’s made A riving knife goes right behind the blade and keeps the wood The riving knife is, ideally, almost as thick as the blade. You can make your own “riving knife/splitter” by installing Next year I think all the saws sold in the US will have riving knives. -- Would you like to recession-proof your present business using the internet? - my revealing 9-page free report gives you the straight facts: http://copymatch.com/rec/cap.html |
357 days ago |
I made a splitter that goes in the blade guard holder. You might want to take at a look a the Shark Guard, it comes with a nice splitter set up. -- Tom, Grove City, Ohio |
355 days ago |
I own the same saw and have never had a kick back problem. One thing does come to mind, have you set the saw up correctly? You will need to make sure that the fence and miter slots are PARALLEL to the blade. On this saw its a really easy adjustment. The owners manual does a good job explaining the process. If the blade is not parallel, healing for example, the wood being cut is pinched between the blade and the fence at the rear and can cause kick back. I would definately check that all the proper set up adjustments are correct. As for the riving knife. This saw is not equipped, it has a splitter that in integrated with the blade guard. -- My job is to give my kids things to discuss with their therapist....medic20447@gmail.com |
355 days ago |
I don’t think that a roving knife is available for your saw. For my craftsman saw, I use a zero clearance insert combined with a MJ splitter by Micro Jig. I also use a Gripper from the same company. While not exactly cheap, they have eliminated (so far) kick back that made a mess of one hand and my (fat) stomach. This combination does not work with a tilted blade, but I have built a sled that I now use if I want to make a beveled cut. The gripper I also find very useful on the router table. Map -- measure once, cut once, swear, start over |
| Forum | Topics |
Woodworking Skill Share
2928 |
3961 |
257 |
955 |
226 |
Woodworking Trade & Swap
622 |
Coffee Lounge
2398 |
LumberJocks.com Site Feedback
524 |
