How much BF of lumber for roubo style bench?
Forum topic by lateralus819 posted 10-20-2013 01:45 AM 1475 views 0 times favorited 12 replies Add to Favorites Watch
View lateralus819's profile
lateralus819
2241 posts in 1798 days
10-20-2013 01:45 AM
I’m thinking of building a workbench this winter. My local hardwood dealer is having their annual halloween sale. 20-50% off plus an additional 5% with costume. So there is huge savings to be had.
I was curious how much BF roughly there is in a typical work bench in the roubo style?
12 replies so far
View Tugboater78's profile
Tugboater78
2729 posts in 2100 days
#1 posted 10-20-2013 02:09 AM
I was under the impression that 100 bd ft would more than cover a top and even less for the base. I will let the more experienced peeps chime in though.
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
Smitty_Cabinetshop
15136 posts in 2527 days
#2 posted 10-20-2013 02:09 AM
Wow, ‘typically’ is a tough nut to crack.
This can be calculated, but of course requires measurements. Thickness of top and legs, length and depth of top, etc. etc.
How big (or small) are you planning to go?
View HorizontalMike's profile
HorizontalMike
7747 posts in 2822 days
#3 posted 10-20-2013 02:10 AM
I can’t answer how much for a Roubo style workbench, but I had between 130 and 150BF in my 21st Century Workbench. I built mine out of Ash, as it was the most affordable in my location at the time.
I would suggest buying more than enough lumber the first time, so that you will be sure of matching the entire project. You can always use the/any additional lumber on other projects later. Regardless of how well you pick your lumber, at some point, some pieces just won’t work for the portion at hand, so having extra always helps.
Good luck! And enjoy the build!
lateralus819
#4 posted 10-20-2013 02:37 AM
Smitty, I’m not really sure. I’m thinking at leas 8’ long. Maybe 3” thick. I’m not sure what a good “standard” is as far as thickness goes.
While I’m at it….I was planning on going with maple, as i think IIRC from the selection they offer. It’s the cheapest and hardest i can get.
What are some suitable woods that are onthe cheaper side? I know poplar is out.
View jmartel's profile
jmartel
7687 posts in 2058 days
#5 posted 10-20-2013 02:45 AM
You’ll want at least 125bdft I’d say. I used about 105 with a bit left over on my 6’ bench.
View Tedstor's profile
Tedstor
1643 posts in 2541 days
#6 posted 10-20-2013 03:05 AM
8 feet long and 3” thick…..how deep?
‘Assuming’ 24” deep, you’d need about 50 bdft- just for the top. Of course, add-in 10% for waste. You’re at 55bdft.
3” thick is beastly. But 2” would be perfectly adequate.
But you’ll want to check my math- I went to public school. LOL/
lateralus819
#7 posted 10-20-2013 03:24 AM
Ah, i thought i had read some were 4”!
I was thinking maybe 3’ deep.
View exelectrician's profile
exelectrician
2327 posts in 2336 days
#8 posted 10-20-2013 03:42 AM
36” deep is too wide to reach across, mine is 29” and I wish it were 25” for practical reasons.
-- Love thy neighbour as thyself
Smitty_Cabinetshop
#9 posted 10-20-2013 03:46 AM
24” across is mine, love it. Too deep is 4”, imho. Thinking anywhere 2.5” to 3” is right, and that’s for ‘whack-a-hold-fast’ functionality (they have difficulty in the thickest of tops).
EDIT: Oh, and anything over 6’ long is dreamy… If your shop can handle an 8’ bench, go for it. The 10% waste factor is sound.
View Mark Kornell's profile
Mark Kornell
1169 posts in 2439 days
#10 posted 10-20-2013 05:37 AM
I recently purchased the lumber for my upcoming Roubo build. 4” thick top, 90” x 24”. 5”X5” legs, plus stretchers and a lower shelf. Including a waste factor, I figured 150 bdft. Haven’t built it yet, so I don’t know how close my estimate is, but I think I’m within 20bdft.
-- Mark Kornell, Kornell Wood Design
HorizontalMike
#11 posted 10-21-2013 01:06 PM
+10 on Smitty’s concern on being (too) Long…
My workbench is 89in + end vise, of just a tad over 7 1/2ft. OR 8ft when the vise is fully open and 30in wide. If I had it to do over, I would seriously think about making it about 2ft shorter in length. I have a 24×30 shop, so technically I have the room, HOWEVER, I do find the size somewhat tedious to deal with on occasion. With a bench this big you really need to be able to work from ALL sides of the bench.
That means having a CLEAR work area of about 8ft x 12ft FOR ONLY THE BENCH with no clutter at all. IMO, that is a lot of space to be dedicated to just one piece of equipment. Just sayin’...
View crank49's profile
crank49
4029 posts in 2879 days
#12 posted 10-21-2013 07:06 PM
Figured for a 3” top, 24” x 84” = 42 BF
for 5” sq. legs, = 25 BF
then 2” x 6” stretchers – 17 BF
I’d add about 25% to all these numbers to allow for waste. Total = 105 BF.
The amount to add for waste all depends on how close to final size you can buy your timbers and how picky you want to be to match grain or avoid knots, etc.
My shop is 23ft square and I do work from all sides of the bench. I have a vise on one side and one end and also a planing crochet on the other side. Works well for me, but everyone is different.
