Finishing options for fall/winter
Forum topic by mds4752 posted 10-20-2013 12:01 AM 928 views 0 times favorited 7 replies Add to Favorites Watch
View mds4752's profile
mds4752
48 posts in 1673 days
10-20-2013 12:01 AM
New woodworker here. What are most folks doing for finishing projects as the weather turns? Due to the fumes and combustibility, do most of you work your projects outdoors until its too cold? I don’t have a ventilation system, nor is one in the budget. I don’t have a heated garage but I can work on my screened porch.
Or does most everyone go ahead and work indoors?
The specific project I’m doing now is with spar urethane and for now, the highs are still in the 50’s & 60’s.
-- "Live each day as if it were your last; one day you're sure to be right." -- Lt Harry "Breaker" Morant
7 replies so far
View Clint Searl's profile
Clint Searl
1533 posts in 2325 days
#1 posted 10-20-2013 12:11 AM
Waterborne finishes.
mds4752
#2 posted 10-20-2013 12:17 AM
Is there a waterborne finish suitable for finishing a piece of outdoor furniture? Will be in Nebraska weather. It was a toss up between spar varnish or spar urethane. I also read about teak oil but I heard more positive rec’s for the spar varnish.
View Purrmaster's profile
Purrmaster
915 posts in 2057 days
#3 posted 10-20-2013 03:31 AM
Even in the cold finishes will dry but they’ll take a lot longer. Lacquer will still work. In some ways I prefer doing lacquer in the cold (I am brushing it) because the longer dry time allows it to level out better. I’ve brushed lacquer in below freezing temperatures. It takes a long time to dry but it does dry.
You can get varnishes to cure more quickly, even in the cold, by making sure you have lots of air circulation by the piece. The reason being that varnish cures by reacting with oxygen. The more oxygen the faster it goes.
Oil finishes don’t work so well in the cold though. I’ve put on raw tung oil in the cold. While it didn’t freeze it didn’t cure until spring. Same thing with oil/varnish blends like Danish oil.
Shellac still works in the cold because alcohol evaporates quickly, even in the cold.
A spar varnish is going to have more oil than an indoor varnish so it may be more problematic in curing.
I haven’t tried waterborne in cold temperatures yet. I suspect it will still work ok because there is glycol in there.
mds4752
#4 posted 10-20-2013 04:43 AM
Purr master—thanks for the insights. I think I’ll give it a shot on my porch. Temps will be in the 50’s and there’s plenty of circulation. Can says 4 hours between coats but as you said, the temps may drag that out. I’m hoping to get by with just 3 coats so we’ll see how it goes.
4949 posts in 2457 days
#5 posted 10-20-2013 01:06 PM
Purrmaster hit it, the solvent finishes will cure, it just takes longer. The evaporative finishes (lacquer/shellac) have no problem with very low temps. I’m not a big water borne guy (yet) but they may actually need warmer temps to coalesce.
mds4752
#6 posted 10-21-2013 12:47 AM
Well the first coat dried in about 4 hours. Gave it a light sanding w/some 220 and am going to put coat #2 on tonight. The temp was 63 today, and the low tonight will be in the 50’s so I should be good to go I hope. Shooting for 3 coats.
Excuse my ignorance but can you provide some examples of water borne products? I’m using Helmsman Spar Urethane for this project. I’m going to research this week some products by Waterlox for a book cabinet I’ll be starting next.
Thanks all.
Purrmaster
#7 posted 10-21-2013 01:42 AM
Waterborne products are things like Minwax Polycrylic. If the can says that it cleans up with water than it’s a water based finish. Water base stuff will look a bit different than solvent based. Usually solvent based finishes have an amber color to them. Water base is typically “water clear” with very little color to it. This can throw you off if you’re used to solvent based stuff.
