Forum topic by HillbillyShooter | posted 10-16-2013 04:25 PM | 1870 views | 0 times favorited | 21 replies | ![]() |
Does anyone know of a nail gun oil that won’t cause polyurethane to leave birds-eyes around the nail hole because the nail gun has injected oil into the area around the nail? I use a 23-gauge pin gun to attach false drawer fronts, but the area around the nail hole has absorbed the gun oil and blocks the adherence of the finish. I wipe the surfaces with thinner before attempting to finish, but it doesn’t seem to remove the absorbed nail gun oil. Should I try lacquer thinner, acetone or something else to dissolve this gun oil? Any suggestions would be appreciated, thanks. -- John C. -- "Firearms are second only to the Constitution in importance; they are the peoples' liberty's teeth." George Washington |
21 replies so far
#1 posted 10-16-2013 05:04 PM |
John, I’ve got 3 nail guns, and I’ve never had that to happen to me…Wonder if you might have a “leak down” in your gun, or hose….? Usually after I shoot the nails (a hair below the surface), I just check it for a splinter or something, then put a tiny dab of filler over the nail hole, wipe it smooth to remove any access, and blend it with the wood…..let it dry for a bit, then I’m ready for the finish…...You might try that just to see if it helps, but I would check the gun also…...That’s strange…...!!!! -- " At my age, happy hour is a crap and a nap"..... |
#2 posted 10-16-2013 05:21 PM |
If thinner didn’t work, the only thing stronger would be acetone. Probably worth a shot. As always, test on an inconspicuous area. Crazy question, but are you over-lubricating your nail gun? When I was an auto tech, I’d see co-workers dump a healthy squirt of oil into their air tools everyday. The tools ran well, and lasted forever, but had oil sweating out of every seal. I probably lubed my tools 1-2 times per week, and only with 2-3 drops. And even now, I lube my nailers every 4-5th use (at most), and never had a problem. Just food for thought. |
#3 posted 10-16-2013 05:23 PM |
Thinking out loud here …. could you place a piece of paper towel over the area you want to nail? It would soak up anything that came out of the gun and in theory, the nail would shoot right through -- Its not a crack, its a casting imperfection. |
#4 posted 10-16-2013 05:30 PM |
2-3 drops per week – In 30 years I’ve never had that problem. -- Sam Hamory - The project is never finished until its "Finished"! |
#5 posted 10-16-2013 05:35 PM |
I agree with Tedstor. It sounds like you may be over lubricating your nail guns. To clean them out, use a shot or 2 of brake cleaner in the air inlet and then shoot a few nails into a scrap board. Then recoil them with just a drop or 2 of air tool oil. Then shoot a few more nails into something and all should be good again. -- Gary,Nebraska |
#6 posted 10-16-2013 05:40 PM |
Thinking back on it, John, I don’t oil mine everytime I use it, either….And like was said, I only put 3-4 drops in. They say to do that, but I’m not so sure you have to oil them after each use….It just depends on how much you use the gun, and then only a few drops…..Uou know the old saying…”A little dab ‘il do ya”..... -- " At my age, happy hour is a crap and a nap"..... |
#7 posted 10-16-2013 05:40 PM |
I put a strip of masking tape on, then shoot the nails. I dab a little filler over the hole in the masking tape, give it a finger swipe and let it dry. A few hours later, I peel off the masking tape, leaving a neat, filled hole that is almost undetectable. -- Gerry -- "I don't plan to ever really grow up ... I'm just going to learn how to act in public!" |
#8 posted 10-16-2013 05:55 PM |
Good idea Dane. I don’t have any issues with the oil. But for a non-fussy way to fill nail holes- that’d be tough to beat. |
#9 posted 10-16-2013 06:00 PM |
Gerry…...Why didn’t you tell me this a couple of years ago….? And here I’ve been doing the hard way all along…..!!!!!! -- " At my age, happy hour is a crap and a nap"..... |
#10 posted 10-16-2013 06:15 PM |
I use oil-free guns for that reason. Bostitch makes some. Another strategy would be to use double sided carpet tape and screws from the inside to attach the drawer fronts (I realize this doesn’t help you now!) -- Willie, Washington "If You Choose Not To Decide, You Still Have Made a Choice" - Rush |
#11 posted 10-16-2013 06:17 PM |
+1 for TheDane’s suggestion. Thats how I have been doing it for years. -- Paul, Las Vegas |
#12 posted 10-16-2013 06:25 PM |
Thanks everyone! Hope everyone picked up or learned something from this thread, I know I’ve learned that I’ve been over lubricating and I’ll be using Gerry’s suggestion of a little masking tape in the future. Willie, the idea of an oil free gun sounds great, but I really like my Cadex and will first try the great advice everyone has been kind enough to share. I guess the real lesson is not to always apply the manual literally, but remember to use a little common sense (which isn’t very common these days). -- John C. -- "Firearms are second only to the Constitution in importance; they are the peoples' liberty's teeth." George Washington |
#13 posted 10-16-2013 07:04 PM |
Hi John. sounds like you got some sound advice. I rarely oil my nailers- maybe a couple drops in a year. I have never experiences what you are talking about. But to get to your current state of things, I’d try lacquer thinner and let it dry and resand the area. I use Bix wood stain filler to fill all nail holes, It can be sanded and stained and that way I don’t have the dimples for the finish to try to “bridge” across Take care, my friend!!!!!!!!!!!!!!!!!!!......................Jim -- Jim Jakosh.....Practical Wood Products...........Learn something new every day!! Variety is the Spice of Life!! |
#14 posted 10-16-2013 08:32 PM |
If you can’t rid your project of the offending oil, let it cure for a couple of days and use a little shelllac on that area to seal the oiled wood, then proceed with your finishing. Best Regards. – Grandpa Len. Work Safely and have Fun. -- Mother Nature should be proud of what you've done with her tree. - Len ...just north of a stone's throw from the oHIo, river that is, in So. Indiana. |
#15 posted 10-17-2013 01:08 AM |
Nice tip Gerry, thanks. I agree with Len, shellac should seal that oil away from your poly. -- " I'll try to be nicer, if you'll try to be smarter" gfadvm |
Forum | Topics |
Woodworking Skill Share
12027 |
Woodturning
2105 |
Woodcarving
431 |
Scrollsawing
340 |
Joinery
1370 |
Finishing
4902 |
6691 |
28047 |
CNC Woodworking
211 |
Hand Tools
5404 |
Jigs & Fixtures
1417 |
Wood & Lumber
6232 |
1387 |
Focus on the Workspace
2153 |
1186 |
Woodworking Trade & Swap
4754 |
LumberJocks.com Site Feedback
2200 |
Coffee Lounge
8844 |
