Should I build something to convert this into a drum sander?
Forum topic by Joshua Oehler posted 10-15-2013 05:30 PM 2239 views 0 times favorited 5 replies Add to Favorites Watch
View Joshua Oehler's profile
Joshua Oehler
169 posts in 1688 days
10-15-2013 05:30 PM
I have this JET brushdrum sander sitting in my garage. I was wondering what you all thought. I was thinking of some kind of platform that I could adjust the height on to make the wood pass between the platform and the bottomside of these sanders. 1 con is these are not very big. only about 12” a pro though would be i could keep 2 different grits of sandpaper on and just simply move from one side to the other. I got this thing for free from my father in law when he moved from FL to OK. I’m not even sure if this is really worth anything either. Am I better off trying to make a drum sander from this or maybe try to sell this thing off and just reinvest the money into my shop?
-- - "But old news can change, as memories float downstream. So don't judge me by my failures, only by my dreams"
5 replies so far
18163 posts in 1853 days
#1 posted 10-15-2013 06:51 PM
Seems like a recipe for shooting hoards through a window, unless you can figure out a feeder to control the piece. Also I would think you need to support the other end of the drum otherwise, as you run something underneath it would flex up on the end. Maybe you could leave one side alone and turn other side into a disc sander with a table in front of it.
View Loco's profile
Loco
210 posts in 1746 days
#2 posted 10-15-2013 08:52 PM
Make a belt sander disk sander out of it.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
Shawn Masterson
1325 posts in 1945 days
#3 posted 10-15-2013 11:35 PM
Personally I would do some research on the value before you tear into it, and have a pile of parts. depending on value and if you can sell it, I would reinvest the funds somewhere else.
View crank49's profile
crank49
4030 posts in 2968 days
#4 posted 10-16-2013 01:31 AM
It’s a good machine, works similar to a spindle sander, but turned 90 degrees.
You probably could sell it to a cabinet shop or a furniture finisher.
Or perhaps build a table above one of the drums to make a “Sand Flee” type sander.
Sand Flee
Joshua Oehler
#5 posted 10-16-2013 02:59 AM
Thank you all for the advice. It seems that the drum sander idea is a overwhelming no. It seems I can combine a couple of these ideas though. Maybe turn one side into a sand flee and the other into a disc sander. Now just to figure out how to do so
