Should I use Metal or Plastic in dust collector refit?
Forum topic by JesseTutt posted 10-14-2013 05:02 PM 955 views 0 times favorited 6 replies Add to Favorites Watch
View JesseTutt's profile
JesseTutt
854 posts in 2229 days
10-14-2013 05:02 PM
Topic tags/keywords: dust collector duct container question
In replacing the plastic bag on the bottom of my Harbor Freight dust collector I am wondering if I should use a metal trash container or a more economical plastic model?
I was planning on metal until I got to wondering if the seams in the metal container would leak over time.
What do you think?
View TheDane's profile
TheDane
5515 posts in 3782 days
#1 posted 10-14-2013 05:09 PM
I used a steel garbage can from the big box … http://lumberjocks.com/reviews/3242
If you’re worried about the seams leaking, run a bead of silicone along them.
JesseTutt
#2 posted 10-16-2013 03:09 PM
Well I got a galvanized steel container from Lowes. As an experiment I filled it with water figuring that I could detect any leaks. I found three. The first and smallest was where the vertical seam met the bottom, this was a small leak. The other two were where the handles were riveted to the sides, these leaks were quite large.
I am debating trying to seal the leaks from the inside (perhaps the air pressure would help push the dried silicon further into the leak), seeing if I could use one of the plastic bags that came with the Wynn filter as a liner, or returning the trash can and getting a plastic one.
There was a comment on Thien’s web site saying that Thien recommends using metal containers. I could not find the original comment by Thien.
What option would you do?
TheDane
#3 posted 10-16-2013 03:39 PM
I ran a bead of silicon on the inside of the seam (didn’t test for leaks … I just assumed it would), and used foil tape (the kind you use on HVAC pipe) on the inside of the handles.
View Loren's profile
10477 posts in 3766 days
#4 posted 10-16-2013 03:41 PM
You may find the flexibility of the rim and position of
the handles on a plastic can complicates fitting and
fastening a sleeve around the rim. Just a speculation
though… I haven’t tried to do one of these modifications.
117203 posts in 3696 days
#5 posted 10-16-2013 03:46 PM
I have used plastic for years but my collection is outdoors making any small leaks not a problem.
View HorizontalMike's profile
HorizontalMike
7770 posts in 3033 days
#6 posted 10-16-2013 03:47 PM
I use a 31gal steel can under my Thien Lid Separator, but use the normal 10mil bag under the HF-DC unit. With the separator catching +99.xx% of the sawdust in the steel can, very little gets deposited in the plastic bag and that rarely needs emptied. Plus the plastic bags seal much better when used with a strip of foam insulation tape ran around the rim of the HF collector.
