All seasons crosscut sled
Forum topic by niki posted 06-16-2007 12:36 AM 1492 views 1 time favorited 8 replies Add to Favorites Watch
View niki's profile
niki
426 posts in 3985 days
06-16-2007 12:36 AM
Good day
Today, I was working on the router table fence, the “Fence/Bit” precision distance system and the “Fence stops” precision positioning system.
I took some 3 Tons of pics but I have to “Delete”, “Sharpen”, “Add Text” etc and it will take some time to post.
In between, I needed a sled to cut small (and not so small) pieces so I made one in 15~20 minutes from the “Floor Panels” left-over that I used for the router table.
I called it “All seasons sled” because temp and humidity changes are not effecting the sled runners that usually are expanding and contracting with humidity changes.
The sled is always tight, without any “Side play” and can be “re-adjusted” in seconds.
Because of the construction method, everything is very square to the blade and no need of “Two cut test” or “Five cut test”...it’s dead 90°…as long as the blade is parallel to the miter slot and your triangle is accurate…
And last, it’s sliding, actually half rolling, and is very, very easy to push-pull.
Many variations can be done on this sled and I leave it to your imagination (I have a few ideas).
Sorry but I did not take any pics of the WIP so if you have any questions, I’m here…
Regards
niki
8 replies so far
35099 posts in 4306 days
#1 posted 06-16-2007 02:50 AM
Great sliding table. Thanks Niki.
View mot's profile
mot
4911 posts in 3942 days
#2 posted 06-16-2007 02:55 AM
Another Nikivention!
View WayneC's profile
WayneC
13751 posts in 4003 days
#3 posted 06-16-2007 06:04 AM
Awesome. Thanks Niki.
View Bob Babcock's profile
Bob Babcock
1804 posts in 3991 days
#4 posted 06-16-2007 06:36 AM
Do you ever stop thinking Niki?...Great stuff.
View niki's profile
niki
#5 posted 06-16-2007 09:12 PM
Thank you
Sorry for the late reply
What I did not tell you (and nobody asked) is that actually the runner is narrower than the miter slot by 1 mm (3/64”) and that’s the reason that it will never bind, get stuck or get loose because of humidity changes.
niki
View oscorner's profile
oscorner
4564 posts in 4216 days
#6 posted 06-19-2007 06:52 AM
It’s only a matter of time and you will devise a way to put ball bearings in a grooved runner, then add a spring and it will make the cut itself. LOL. Way to go, niki.
-- Jesus is Lord!
View David's profile
David
1970 posts in 4044 days
#7 posted 06-19-2007 04:57 PM
Niki -
Awesome sled! I always enjoy your very detailed and well engineered postings. Thanks!
View niki's profile
niki
#8 posted 06-19-2007 08:46 PM
Thank you for the compliments
Oscorner
Maybe one day I’ll make it….how knows…but not with the spring, all my fun is pushing the sled…:)
David
Well, this post is not so detailed…all the “step-by-step” includes 56 pictures…I just selected a few…
Regards
niki
