Help needed retro-fitting a Unifence
Forum topic by kmerkle posted 10-14-2013 11:00 AM 865 views 0 times favorited 0 replies Add to Favorites Watch
View kmerkle's profile
kmerkle
33 posts in 2335 days
10-14-2013 11:00 AM
Topic tags/keywords: unifence retrofit fence install tablesaw
I bought an older version 32” Unifence (I think it’s a 34-897) off CL yesterday for $40. I know—deal of a lifetime!.
Now to install it on my newer model Craftsman TS 21833. I was hoping someone could take a couple of measurements on their Unisaw to get me going.
I need to figure out where to drill new holes in the rail for the correct height and horizontal position. Page 4 and 5 of this pdf gives a visual of what I’m trying to accomplish.
http://vintagemachinery.org/pubs/1141/5760.pdf
1. What is the vertical distance from the table surface to the flat surface of the rail. In other words, what do I set the height of the rail to? Figure 16 in the pdf.
2. What is the distance from the right side of your 1/8” kerf blade to the 0” mark on the measuring tape? In other words, where do I position the rail horizontally with respect to the blade so that it is within the adjustment range of the cursor?
Any other advice or suggestions is greatly appreciated!
Kurt
-- Every project is perfect until it's started.
0 replies so far
