belsaw craftsman planer, extension table question
Forum topic by sniper695 posted 10-14-2013 10:57 AM 1301 views 0 times favorited 11 replies Add to Favorites Watch
View sniper695's profile
sniper695
5 posts in 1599 days
10-14-2013 10:57 AM
I just picked up a craftsman branded belsaw planer, with the 5hp motor, seem like its had very little use. but it has very bad snipe issues, I would like extensoin tables for it, is that something you can buy affordably? or any advice on how to make them? I have a welder and basic welding skills.
also any advice on how to setup a dust collector attachment?
11 replies so far
Shawn Masterson
1324 posts in 1856 days
#1 posted 10-14-2013 12:11 PM
I have had 2 of them and used many others. Honestly it just seems to be the nature of the machine. Every one I have ever used does the same thing. It scarfs out the last 6” of the board. I work with rough sawn domestic lumber, so it never really bothered me, but I understand your trouble.
View Planeman40's profile
Planeman40
1105 posts in 2668 days
#2 posted 10-14-2013 07:55 PM
I’ve had a “Craftsman” Belsaw planer for around 35 to 40 years. Bought it new. I have the metal extensions on it that came with it. When I installed them after I bought it I remember being VERY careful to align the extensions to be parallel and even with the machine table. I have absolutely NO SNIPE. Check the extension alignment very carefully!
I find the Belsaw planer to be a GREAT machine. It just looks ungainly.
Planeman
Planeman40
#3 posted 10-14-2013 07:57 PM
Oh, and I see no reason why with a little thought you couldn’t make some very nice table extensions out of either metal or wood. There is no secret as to how they work. They are very simple.
Planeman
View Loren's profile
9970 posts in 3555 days
#4 posted 10-14-2013 08:24 PM
If you don’t mind throwing off the scale (or fashioning a new pointer)
you can make a bed from melamine that extends fore and aft.
I recently sold my Belsaw. I liked it a lot but I acquired something
bigger and don’t have room to keep both. An infeed table isn’t
needed much but an outfeed table helps a lot. I never had
snipe if I lifted boards as they came out – though it did take
some time to get a feel for how to do it.
Woodmaster extension tables fit the Belsaw. They are probably
pricey but I’m sure Woodmaster has them available.
View Don W's profile
Don W
18606 posts in 2475 days
#5 posted 10-14-2013 08:59 PM
I have one as well. I made some extensions.
#6 posted 10-14-2013 09:03 PM
If you make your own, there are two holes to bolt to
the Belsaw, but also a couple of tapped holes for set
screws which you use to adjust the table angle.
Don W
#7 posted 10-14-2013 09:09 PM
I use something like this
sniper695
#8 posted 10-14-2013 09:12 PM
Anyone who made extension can you post pics? If you made them out of metal how do you keep them flat and square?
Don W
#9 posted 10-14-2013 09:50 PM
There are pictures here, http://lumberjocks.com/donwilwol/blog/31939
its metal, so if it starts flat, it stays flat. I don’t think square really matters.
sniper695
#10 posted 10-18-2013 11:54 AM
my planers doesn’t appear to have holes for extensions. I just found some table tops, kinda like a counter top. that has hard flat surface on top. they seem very stiff. if i cut it so it can lay on the table and extend out maybe 12 inches to either side, would that work? with a board on either side on bottom so it stays in place. I don’t ever see the need to plane something 6 inches thick and if I did I can remove the counter top board.
kinda of like loren’s idea just free :)
they are about 1 1/4 inch thick, seem very strong.
Don W
#11 posted 10-18-2013 12:13 PM
sniper695, I did the exact same thing with my benchtop, but I only used 1” lumber and it worked well.
