minwax high build poly will not dry
Forum topic by Stevebro posted 10-14-2013 10:50 AM 8169 views 0 times favorited 13 replies Add to Favorites Watch
View Stevebro's profile
Stevebro
5 posts in 1655 days
10-14-2013 10:50 AM
Well I hope I can get some help with this. I bought some minwax high build polyurethane varnish hoping I could put 1 or 2 coats on a table and be done. I put on 1 coat and found I easy though almost immediately i had brush drag when I tried to smooth out brush marks. The table was in my air conditioned kitchen and to my shock it was not dry the following day. In fact a week later it was still tacky. After 9 days it seemed dry and we had friends over to dinner. On cleaning up I say the impression of our plates on the finish through a cloth place mat. I called minwax, who suggested letting it dry and wiping down with thinner to accelerate the drying. I have let the table be for 4 months, but am wondering how do I go about repairing the finish? Can I just sand out the marks and recoat? Or do I have to strip this table. It is walnut and had been oiled a month before I applied varnish. Minwax said light sand and a coat of their fast dry, but I am leery of their products now.
thanks, Stephen
13 replies so far
View hydro's profile
hydro
208 posts in 1658 days
#1 posted 10-14-2013 11:39 AM
You identified the problem at “oiled a month before”. Did you use “Boiled Linseed Oil”? That stuff takes forever to cure and the oil was likely not completely catalyzed. That will inhibit the dryers in the poly top coat. Since this is a table top and will be subject to use, I would strip it down and re-finish.
Once stripped, sand lightly, use a stain base coat, let cure for 2+ days, then re-do the poly coats. Personally, I would use clear gloss poly for the build coats since it does not contain flatteners that cloud the finish. If you want a satin look, use the satin or semi-gloss for the top coat only.
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
4881 posts in 2400 days
#2 posted 10-14-2013 11:44 AM
Well, I’ll throw in my 2¢. I wouldn’t try to repair, but at this point you may have nothing to loose. Smoothing it out (I would try a card scraper) and then recoating it may solve the problem. If you are unhappy with it, then a strip and re finish may be in order. If you try the smooth and recoat approach, the new finish doesn’t need to be a brushed on thick coat, you could thin some 50/50 with mineral spirits, and wipe the new coat on with a cloth. I want to add something. I was surprised at what the Minwax rep told you. Varnish is a reactive finish, that is the varnish (resins cooked together with a drying oil) actually chemically combines with oxygen (reacts) to cure. Putting thinner on it does nothing to speed that process up, though it probably didn’t slow it down any either. The thinner would simply evaporate and the varnish keeps curing. Adding a bit of air movement, and maybe some warmth would both speed up the reaction. I’m not sure what you mean by “oiled a month before”, but I’m doubtful it caused the problem. Regardless of what you try, I wish you the best.
hydro
#3 posted 10-14-2013 01:06 PM
Fred, I have to disagree with your comment on the oil. That is the only “wild card” in the OP. If Minwax was applied over dry walnut, there is no reason for it not to cure. Since the OP did not specify the type of oil, I would guess it had some effect on the driers of the Poly finish.
View JustJoe's profile
JustJoe
1554 posts in 1945 days
#4 posted 10-14-2013 01:43 PM
True, but minwax doesn’t need a reason not to cure, it just does what it wants when it wants. My own experience with applying minwax over a clean, bare surface is over in the review section (search for “lemon marmalade”).
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
#5 posted 10-14-2013 02:20 PM
There will always be differences of opinion on forums like this. I’ve used a lot of BLO, and the most I ever waited for it to dry was one week when being top coated with waterbornes. I’ve never had a problem with anything not curing on top of it once the BLO itself had cured enough. With most other finishes I only wait one day, with shellac even less (same day, sometimes). Now, the OP said the table was oiled a month before he topcoated; I would bet the month’s SS check (if they get sent out) that if it was BLO it didn’t impact the curing of the varnish. I didn’t say in my original replay, but I was thinking along the lines ofwhat Justjoe said about Minwax. I consider them the Harbor Freight of the finishing world (I hope that isn’t too insulting to HF).
View BinghamtonEd's profile
BinghamtonEd
2286 posts in 2276 days
#6 posted 10-14-2013 02:42 PM
I had a similar experience with Minwax High-Build, and I didn’t use any oil. I applied a sealcoat of 1LB dewaxed shellac, which was sanded back when dry. About a week later I put on 2-3 coats of the Minwax, it seemed to go fine. A couple weeks later it went into my daughters room, and the little alarm clock on top left an impression in the finish. I switched to Arm-R-Seal as my go-to finish and have not had any problems since.
Stevebro
#7 posted 10-14-2013 07:16 PM
Thanks fellas for some ideas. I have given away the balance of the minwax high build and moved to arm r seal. After reading a review by a poor guy who coated all the floors in his house, I feel better. He could not recoat or walk on them for a week. I am going to try a little light sanding/scraping to see if I can smooth the ridges and recoat with minwax fast dry for 2 reasons.
1. The manufacturer recommended this and said it will adhere well. 2. I cringe at the thought of a complete strip of a walnut veneer table top. I can just see the veneer peeling off. Steve
BinghamtonEd
#8 posted 10-14-2013 07:49 PM
If you’re going to do that, you may try thinning it a bit and wiping it on (I use a blue shop towel, the kind that look like paper towels…but blue. They don’t leave lint or fall apart when soaked). Sounds like you have a coat built up already, and you don’t need much build. If you sand it smooth and do a couple real thin wiping coats, you may be in business. Only caveat here is I’m not sure how thinned the “Fast Dry” mixture really is.
Stevebro
#9 posted 10-14-2013 08:02 PM
Thanks Ed, I think I will try wiping the minwax fast dry on a scrap and see how it goes. I have about 4 spots to sand.
Wen I am through I will donate the leftover minwax products to the local Restore. The silver lining is this disaster has pushed me to find new products to use and indeed to find this forum. I have now been using arm r seal with success and about to try waterlox on a project. Lots of good info on this site. Thaks to al for the help. Steve Brown
BinghamtonEd
#10 posted 10-15-2013 11:48 AM
Glad you’ve found something that works for you. Before I got into woodworking, I thought poly was poly, and Minwax was reputable stuff. Once I started using better finishes, I was amazed at the difference.
View trez's profile
trez
1 post in 69 days
#11 posted 12-15-2017 09:50 AM
Glad you ve found something that works for you. Before I got into woodworking, I thought poly was poly, and Minwax was reputable stuff. Once I started using better finishes, I was amazed at the difference.
- BinghamtonEd
i need a coach ….refinish oak table top.i like the high build look.
last minwax product i bought was disappointing.can i get something good at home depot ?
View EricTwice's profile
EricTwice
230 posts in 440 days
#12 posted 12-15-2017 10:52 AM
I’ve had problems with poly drying also, I concluded it was a combination of: temperature (it was near freezing), humidity (90%), age of product (who knows how long it was on the shelf) and possible contamination (something on the wood)
all of these can effect the way polyurethane drys/cures.
I have never had problems with Minwax on a warm dry day when working on clean wood with a fresh can of finish. However when one or more of the above problems are present, you take your chances, but note that though these can cause problems, they are all fixable.
I hope this is helpful
-- nice recovery, They should pay extra for that mistake, Eric E.
View OSU55's profile
OSU55
1522 posts in 1896 days
#13 posted 12-15-2017 01:23 PM
Use a lot of MW poly and dont have a problem with it, but I dont use it for a fully filled, thick film finish (spray wb for that). From your description it “sounds” like you put a pretty thick heavy coat on, so Im not that surprised its taking a long time to fully oxidize. FYI MW is ~42% solids and ARS is ~31% solids. More solids build faster but take longer to cure. Its a good idea to thin the MW 20% or so for any coat.
