Weatherproof paint
Forum topic by Wayne Corners posted 10-14-2013 10:17 AM 524 views 0 times favorited 2 replies Add to Favorites Watch
View Wayne Corners's profile
Wayne Corners
4 posts in 1822 days
10-14-2013 10:17 AM
Topic tags/keywords: weatherproof paint weather
I’m repainting the facade around my front door and found that the 6’x1’ top had rotted and needed to be replaced. I’ve built the replacement from doug fir. This top will be exposed heavily to sun, rain, and snow will collect on it for short periods of time. I am using Sherwin Williams Duration Exterior Acrylic Coating for the facade. Is this, along with a good exterior primer, sufficient to protect the top? Is their something else I can do to preserve it? Thanks a bunch for your help.
2 replies so far
View oldnovice's profile
oldnovice
6847 posts in 3365 days
#1 posted 10-29-2013 09:02 PM
For my! severe duty” work I use Rust Oleum high gloss enamel and it really has worked out for me so far. It’s not cheap but than what good quality paint is?
I don’t know if this will help but Rust Oleum has a product called Neverwet coating that may help repel water, no water = no rot.
You can also Google Neverwet and see some of the videos on how it works and check with Rust Oleum to see how it would help, if any, your application.
Wayne Corners
#2 posted 11-03-2013 03:37 PM
I will look into the Rust Oleum. Thanks a bunch for the tip.
