Repelling Magnetic Projects
Forum topic by CptWingnut posted 10-13-2013 12:00 PM 1170 views 2 times favorited 5 replies Add to Favorites Watch
View CptWingnut's profile
CptWingnut
34 posts in 2910 days
10-13-2013 12:00 PM
I am wondering if anyone has ever done any sort of repelling magnetic projects, on this scale or smaller?
http://www.gizmag.com/float-table-wooden-blocks/29257/
and what would be the important steps in planning something like this? i.e. magnet placement or cable tension/placement or how to raise the money to have somebody else make it?
5 replies so far
View abie's profile
abie
882 posts in 4012 days
#1 posted 10-13-2013 02:13 PM
Interesting…
how do you attach the cables??
How do you assemble it all
I, For one , would love more information…
-- Bruce. a mind is like a book it is only useful when open.
View skipj's profile
skipj
97 posts in 2514 days
#2 posted 10-13-2013 02:34 PM
Plus 1 with abie said
View Makarov's profile
Makarov
102 posts in 2047 days
#3 posted 10-13-2013 02:34 PM
Don’t set your watch or a computer drive near it. And moving it would be ingesting.
-- "Complexity is easy; Simplicity is difficult." Georgy Shragin Designer of ppsh41 sub machine gun
View Ozwald's profile
Ozwald
42 posts in 1954 days
#4 posted 10-13-2013 03:22 PM
I could be way off, but from the pictures it doesn’t look too complex. Obviously the blocks are veneered to get the magnets inside. I would assume to make the blocks you would take a wooden cube, drill a hole with a forstner bit to the thickness of the magnet & glue in place. I would also guess that it only consists of 1 (or a small number) of longer cables, in which case you’d drill a tight fitting hole all the way through each block and a corresponding hole in the veneer before it’s glued on. Then thread the cable(s) before the veneer is glued in place – the veneer glue should be enough to keep the blocks from sliding along the cable, but it also wouldn’t be too hard to add a touch extra before the veneer glue up. I think the toughest part would be the geometry of the cable & not mixing up all the parts before threading/gluing.
Even if that’s not the way they did it, it’s a fun idea for a table.
-- When at first you don't succeed, get a bigger hammer.
View Mark Shymanski's profile
Mark Shymanski
5623 posts in 3954 days
#5 posted 11-12-2013 12:03 AM
Thanks for posting this, a very intersting use of magnets and a novel furniture piece.
