bent lamination strips
Forum topic by VTdscglfr posted 10-12-2013 03:54 AM 915 views 0 times favorited 2 replies Add to Favorites Watch
View VTdscglfr's profile
VTdscglfr
23 posts in 1783 days
10-12-2013 03:54 AM
Topic tags/keywords: bent lamination lamp
Hey all,
Does anyone have any ideas on using a belt sander in place of a drum sander for creating strips for bent lamination. I have a 3 inch wide belt sander so I will be liminited in width. If anyone has any ideas for good jigs or some other ideas that would be great. Or if you have any other ideas that would be good as well. Is 1/8 to thick for bent lamination? Our cat knocked off my wifes lamp for our bedroom and I want to build her one with LED’s
2 replies so far
9973 posts in 3556 days
#1 posted 10-12-2013 03:57 AM
If you have a table saw you can rip them well enough with a good
ripping blade. No thickness sanding required.
View KnickKnack's profile
KnickKnack
1088 posts in 3474 days
#2 posted 10-12-2013 04:37 PM
…or some other ideas that would be great
It’s fairly easy to make a “sanding wheel” for a drill or drill press – I made one which you can see in use here and here.
-- "Do not speak – unless it improves on silence." --- "Following the rules and protecting the regulations is binding oneself without rope."
