Burning rings in bowls
« back to Woodturning forum
Forum topic by kmetzger posted 10-11-2013 03:08 AM 2231 views 0 times favorited 4 replies Add to Favorites Watch
View kmetzger's profile
157 posts in 1751 days
10-11-2013 03:08 AM
Please scroll forward in this video to 3:20 minutes:
What is this turner using to burn the rings? A piece of wood?
-- Kim, Ajijic, Mexico,
View UncleStumpy's profile
734 posts in 2246 days
#1 posted 10-11-2013 09:00 AM
Boy, I would like to know that myself! It does look like a piece of wood, but it seems like it wears away too fast to be wood. Maybe cork? I thought maybe paint, but when he does the second ring, he doesn’t dip it in anything.
I hope somebody can answer this!
-- "They don't want it perfect - they want it SPECIAL"
View doubleDD's profile
7220 posts in 1977 days
#2 posted 10-12-2013 12:49 AM
I use a piece of hardwood when I need to burn anything wider than the wire thickness. It works great. The piece of wood will wear away quickly depending on how much pressure is applied.
#3 posted 10-12-2013 12:59 AM
Yes, hardwood, I think. I just found this:
Once you have determined the design, use a sharp skew chisel, lay it flat on the tool rest, and cut the design lines with the long end of the skew. These lines should be 1/16” deep and 1/32” wide. Now, fold a piece of abrasive paper into a shape that will fit into the cut grooves. With the lathe running at the same speed as for sanding, friction burn the lines with the abrasive paper. Another material to use for burning the lines is a credit card (you probably have a credit card which should be burned anyway). I have also used a hardwood stick, sharpened on the sander to a knifeā€™s edge to fit inside the grooves. If this technique does not produce the effect you want, use a sharp, felt-tipped marker to mark the lines. If you elect to use a marker, be sure to cut the lines so the marker will have a guide to follow; light sanding will remove any unwanted lines or burn residue from the workpiece.
View TheDane's profile
5384 posts in 3596 days
#4 posted 10-12-2013 02:18 AM
Another way to burn lines is with formica … some of the guys in our turning club use the little formica samples you get at the big box stores.
