How to repair this bench
Forum topic by dschlic1 posted 10-10-2013 10:12 PM 1051 views 0 times favorited 7 replies Add to Favorites Watch
View dschlic1's profile
dschlic1
408 posts in 1879 days
10-10-2013 10:12 PM
Topic tags/keywords: question refurbishing joining
Attached is a photo of an old bench from Guatemala. It is probably 40 or 50 years old. As you can see one of the legs broke. I would suggestions as how to repair this leg. It does not have to look perfect.
7 replies so far
116913 posts in 3486 days
#1 posted 10-10-2013 10:27 PM
A new leg all the way to the top is the best solution and perhaps the easiest . If you measure the old piece first and then cut it into small pieces around the joinery it should come apart fairly easy.
View Clint Searl's profile
Clint Searl
1533 posts in 2270 days
#2 posted 10-10-2013 11:05 PM
Glue and screw a splint on the side and back.
View bondogaposis's profile
bondogaposis
4611 posts in 2260 days
#3 posted 10-10-2013 11:23 PM
Beyond repair, replace like a1jim recommends.
-- Bondo Gaposis
View tefinn's profile
tefinn
1222 posts in 2346 days
#4 posted 10-11-2013 12:19 AM
Drill a hole in the center of each piece and use a dowel to join it back together. A little more difficult to do with the jagged break, but it can be done.
-- Tom Finnigan - Measures? We don't need no stinking measures! - Hmm, maybe thats why my project pieces don't fit.
dschlic1
#5 posted 10-11-2013 08:10 PM
I am reluctant to try and replace the leg. First I have no idea what the existing wood is, more than likely some kind of tropical hardwood un available in the US. Second I have no idea what the current finish is.
Combining ideas from Clint and Tom how about gluing the leg back on and then rout a slot (or two) in the back of the repaired leg and then glue in a popular or oak slat(s)?
tefinn
#6 posted 10-11-2013 08:34 PM
As long as you can get the break to close completely that would work very well. It would be a visible repair, but an accepted method.
View Loren's profile
9981 posts in 3557 days
#7 posted 10-11-2013 08:41 PM
I have repaired broken chairs by butt gluing the parts together
and after the glue dries I use a plunge router to mortise out a slot
for a spline.
