Psychology 101 -
« back to Coffee Lounge forum
Forum topic by Dan'um Style posted 10-09-2013 11:32 PM 2183 views 0 times favorited 29 replies Add to Favorites Watch
View Dan'um Style's profile
Dan'um Style
14172 posts in 3978 days
10-09-2013 11:32 PM
Psychology 101 -
If you start with a cage containing five monkeys and inside the cage, hang a banana on a string from the top and then you place a set of stairs under the banana, before long a monkey will go to the stairs and climb toward the banana.
As soon as he touches the stairs, you spray all the other monkeys with cold water.
After a while another monkey makes an attempt with same result… all the other monkeys are sprayed with cold water. Pretty soon when another monkey tries to climb the stairs, the other monkeys will try to prevent it.
Now, put the cold water away.Remove one monkey from the cage and replace it with a new one.
The new monkey sees the banana and attempts to climb the stairs. To his shock, all of the other monkeys beat the living daylights out of him. After another attempt and attack, he knows that if he tries to climb the stairs he will be assaulted.
Next, remove another of the original five monkeys, replacing it with a new one.
The newcomer goes to the stairs and is attacked. The previous newcomer takes part in the punishment…... with enthusiasm, because he is now part of the “team”.
Then, replace a third original monkey with a new one, followed by the fourth, then the fifth. Every time the newest monkey takes to the stairs, he is attacked.
Now, the monkeys that are beating him up have no idea why they were not permitted to climb the stairs. Neither do they know why they are participating in the beating of the newest monkey.
Finally, having replaced all of the original monkeys, none of the remaining monkeys will have ever been sprayed with cold water. Nevertheless, not one of the monkeys will try to climb the stairway for the banana.
Why, you ask? Because in their minds…that is the way it has always been!
This, my friends, is how Congress operates… and this is why, from time to time:
ALL of the monkeys need to be REPLACED AT THE SAME TIME.
29 replies so far
View lew's profile
lew
12056 posts in 3751 days
#1 posted 10-09-2013 11:35 PM
AMEN!
View eddie's profile
eddie
8565 posts in 2609 days
#2 posted 10-09-2013 11:51 PM
sounds like a good plan to me , but whos going to bring the bananas
-- Jesus Is Alright with me
13603 posts in 3336 days
#3 posted 10-09-2013 11:53 PM
all the govt. has to do
is buy all the golf courses
it will never shut down again !
View kdc68's profile
kdc68
2657 posts in 2272 days
#4 posted 10-10-2013 12:16 AM
-- Measure "at least" twice and cut once
117090 posts in 3572 days
#5 posted 10-10-2013 12:29 AM
I’ll go one up, replace all the monkeys with intelligent caring people.
eddie
#6 posted 10-10-2013 12:52 AM
23916 posts in 3846 days
#7 posted 10-10-2013 12:56 AM
We have the same problem Down Under. Always some sort of ‘monkey business’
View redryder's profile
redryder
2393 posts in 3097 days
#8 posted 10-10-2013 06:03 AM
Term Limits…...................
-- mike...............
View Tugboater78's profile
Tugboater78
2743 posts in 2187 days
#9 posted 10-10-2013 07:03 AM
F’n monkey business
-- "....put that handsaw to work and make it earn its keep. - summerfi" <==< JuStiN >==>=->
View Toolz's profile
Toolz
1004 posts in 3738 days
#10 posted 10-10-2013 01:05 PM
Amen redryder!
-- Larry "Work like a Captain but Play like a Pirate!"
View LukieB's profile
LukieB
966 posts in 2325 days
#11 posted 10-10-2013 01:17 PM
Good stuff, thanks for sharing
-- Lucas, "Someday woodworks will be my real job, until then, there's this http://www.melbrownfarmsupply.com"
View wiswood2's profile
wiswood2
1138 posts in 3691 days
#12 posted 10-10-2013 03:23 PM
You got it right redryder, and the sooner the better.
Chuck
-- Chuck, wiswood2 www.wisconsinwoodchuck.com
View redSLED's profile
redSLED
790 posts in 1888 days
#13 posted 10-10-2013 03:38 PM
So far everyone agrees. So how will all of congress get replaced?
View PineChopper's profile
PineChopper
187 posts in 2192 days
#14 posted 10-10-2013 03:39 PM
So True!!!!!!!!!!!!!!!!!!!!!!!!
#15 posted 10-10-2013 03:45 PM
Impeach them !!!!
showing 1 through 15 of 29 replies
