Building covered patio structure
Forum topic by brantley posted 10-09-2013 04:57 PM 1772 views 0 times favorited 7 replies Add to Favorites Watch
View brantley's profile
brantley
185 posts in 3495 days
10-09-2013 04:57 PM
Topic tags/keywords: question patio
I am going to be building an gable roof open structure over my patio outside. Right now i have a 14×17 slab. Im wanting to expand it to roughly 17×20. I just have a few questions on materials so i can price materials at this point. Would 6×6 pt’d post suffice. (This will be free standing but close to the house)
For the roof structure would 2×6 framing lumber work? I could use pt’d lumber on the outside.
What are people using on the roof ? Osb or plywood?
Does anybody have a picture or a link of just a basic gable roof structure with open sides? I have been looking all over google and all i can find is structures that are decorative not really what im looking for. Thanks
7 replies so far
brantley
#1 posted 10-10-2013 12:44 AM
View newwoodbutcher's profile
newwoodbutcher
780 posts in 3088 days
#2 posted 10-10-2013 01:09 AM
Yes, I think bot sizes are appropriate
-- Ken
View higtron's profile
higtron
247 posts in 2915 days
#3 posted 10-10-2013 01:35 AM
You could build this structure using pole barn construction. Pole barn construction the Pole is the foundation you bury a 6×6 pt post 4’ in the ground and you build the rest of the structure off the posts. Here are some pictures of my shop that I built using this construction technique. https://s3.amazonaws.com/vs-lumberjocks.com/mufiuty.jpg!
-- A friend will help you move, a good friend will help you move a body
View AandCstyle's profile
AandCstyle
3185 posts in 2495 days
#4 posted 10-10-2013 01:40 AM
Brantley, I think 6×6 posts should be fine for this sized structure, but something for you to consider is to laminate 3 PT 2×6s together using 20d nails. Cut them 3 different lengths to get them 12” above ground level, say 12”, 24” and 36” offset. Then do the same with 3 regular 2×6s so they interlock with the PT pieces to get the total length you require. I know that I am not describing this well, but hopefully you will understand. The benefit is that you are using that much less expensive PT lumber and by laminating 3 pieces together you will have all the strength you need. I did this once for pole barn construction and it worked fine. HTH
-- Art
View straycat's profile
straycat
3 posts in 1935 days
#5 posted 10-10-2013 05:59 PM
We bought plans here:
http://www.decks.com/deckplans/Low_Elevation_Decks/1PG1616
Here is the first stage connect to the roof of the house:
Used 6×6 corner posts and 4×4 on sides
We used 2×6 rafters on beam constructed from 3 – 2×12 Douglas Fir
Used plywood for the roof
Completed framing
Screen installed and ready for relaxation
View agallant's profile
agallant
551 posts in 3124 days
#6 posted 10-10-2013 06:18 PM
I used OSB on my rood. I wish I sprung the extra cash for plywood.
View dhazelton's profile
dhazelton
2805 posts in 2534 days
#7 posted 03-29-2014 12:30 PM
I don’t know how anyone can answer your questions without seeing a plan. We don’t know the length of the joist span or how far apart your posts will be.
