Mallet wood question
« back to Woodcarving forum
Forum topic by Belg1960 posted 10-08-2013 11:15 PM 1275 views 0 times favorited 7 replies Add to Favorites Watch
View Belg1960's profile
Belg1960
1067 posts in 3060 days
10-08-2013 11:15 PM
Topic tags/keywords: question turning milling
I have some real nice sections of cherry that are about 12” across and wonder is the very center of a log the densest and best section to use for mallet making or turning? Thanks Pat
-- ***Pat*** Rookie woodworker looking for an education!!!
7 replies so far
View bluekingfisher's profile
bluekingfisher
1250 posts in 2974 days
#1 posted 10-09-2013 09:55 AM
Pat, I’m no turning expert but I believe I read soem time ago when turning the best meth is to turn it end ofr end rather than turning down the diameter of the trunk/butt.
I’m sure someone will come along and provide you with the relevant advice.
Good luck
David
-- No one plans to fail, they just, just fail to plan
View rommy's profile
rommy
13 posts in 1686 days
#2 posted 10-09-2013 10:42 AM
I am agree with you, this is the nice information related to cherry section of denest.
-- buy sildenafil citrate, http://www.youmeds.com/buy-sildenafil-citrate-100mg-online
View plantek's profile
plantek
312 posts in 2794 days
#3 posted 10-09-2013 01:17 PM
In turning, the center of the log (the pith) is usually cut out due to cracks/checks being prone to start there. When I get a round of wood my first cut with the chain saw is through the center. I then cut desired sized blocks from the two halves.
The rule of thumb for grain direction is typically as follows:
Grain running horizontal to your lathe bed = spindle work
Grain running vertical to your lathe bed = bowl work
Of course that is just a rule of thumb.
-- If you want it and it's within reason... It's on it's way!
View Loco's profile
Loco
210 posts in 1744 days
#4 posted 10-09-2013 01:21 PM
If you want to make a wooden mallet you need Hymenaea courbaril …in merican that’s Jatobá.
-- What day is it ? No matter. Ummmm What month is it ? No moron. I paid for a 2 x 6. That means Two inches by six inches. I want the rest of my wood.
View Bill White's profile
Bill White
4928 posts in 3955 days
#5 posted 10-09-2013 02:35 PM
Dogwood from the base/root area. That’s what I used for my froe maul. Hasn’t split yet.
Got that tip from Sir Roy Underhill.
Bill
-- bill@magraphics.us
View SteviePete's profile
SteviePete
226 posts in 3298 days
#6 posted 10-14-2013 12:26 AM
I’ve found weight to be the most important factor for a carving mallet. Find a pleasing design, make a smallish one and a large one. Use each and add/subtract weight til you find one thats comfortable over a long period of use. I ended with an old used (one) light weight, two a square headed 20 oz american hop hornbeam, and two rummage sale rounders both very light—even granny would need some wt. 4-8oz. Use yellow birch, soft red maple, am. hop hornbeam, red elm, hickory to rehandle most of the wackers. I stay away from pith and youngwood sections in the wackers. Use nicer stuff for tool handles. On Wisconsin!
-- Steve, 'Sconie Great White North
Belg1960
#7 posted 10-14-2013 10:46 AM
Great info guys, I really appreciate it. I salvaged two blanks out of the cherry (I think) I also cut a few small straight flat pieces for a couple small projects. Is there a blog or link for how to store them on the forum?
