What would these lathe tools be used for?
« back to Woodturning forum
Forum topic by Woodknack posted 10-08-2013 02:59 AM 1692 views 0 times favorited 18 replies Add to Favorites Watch
View Woodknack's profile
Woodknack
11631 posts in 2380 days
10-08-2013 02:59 AM
Topic tags/keywords: lathe
These were in a box of old lathe tools I bought and were ground from old Buck Bros tools. They work okay as scrapers but not as skews.
18 replies so far
View Chris Peroni's profile
Chris Peroni
101 posts in 1939 days
#1 posted 10-08-2013 03:29 AM
they look like parting tools to me
-- Never discourage anyone...who continually makes progress, no matter how slow. -Plato
View WayneC's profile
WayneC
13754 posts in 4098 days
#2 posted 10-08-2013 03:30 AM
Me too…
View doubleDD's profile
doubleDD
7387 posts in 2043 days
#3 posted 10-08-2013 04:36 AM
Me three.
Woodknack
#4 posted 10-08-2013 04:37 AM
Never seen a slanted parting tool. I can give it a try to see if they work that way but I don’t believe they will.
doubleDD
#5 posted 10-08-2013 04:41 AM
Try it and see what happens. Let us know.
View THOMRIDER's profile
THOMRIDER
104 posts in 3068 days
#6 posted 10-08-2013 10:29 AM
They look like scrapers for tight detailed areas to me. Probably a custom grind job
-- Its all about the jigs
View Underdog's profile
Underdog
1097 posts in 2036 days
#7 posted 10-08-2013 12:47 PM
The smaller one looks like a parting tool that’s been ground into a diamond tip tool. I’m not familiar with how it’s used. You could regrind it so that it could be used as a parting tool.
The larger one is ground the same way. As ThomRider indicated, I suspect they were both used as scrapers so as to get detail.
In my opinion, you can get better shaped and more crisp detail with a spindle or detail gouge. I would repurpose the smaller one as a parting tool, and use the larger one as a scraper to get square inside corners in hollowing work; like turned boxes.
-- "woodworker with an asterisk"
View Cliff De Witt 's profile
Cliff De Witt
130 posts in 2693 days
#8 posted 10-08-2013 01:08 PM
To me they look like homemade versions of Ray Key’s Dual Angle Shear scrapers.
With those bevels they certainly are not parting tools, but scrapers for the finishing cuts.
-- Trying to find an answer to my son’s question: “…and forming organic cellulose by spinning it on its axis is interesting, why?”
View Wildwood's profile
Wildwood
2306 posts in 2135 days
#9 posted 10-08-2013 01:28 PM
Looks like those tools modified for use as a shear point scraper, dove tail tool or diamond parting tool.
Check out crafts supply catalog and will see what each one of tools I mention, hence my opinion your tools modified!
-- Bill
View PurpLev's profile
PurpLev
8535 posts in 3649 days
#10 posted 10-08-2013 01:35 PM
most likely custom ground scrapers for a specific shape/turning the previous owner was fond of or used often in his turnings.
View TheDane's profile
TheDane
5423 posts in 3663 days
#11 posted 10-08-2013 02:01 PM
Could they be for cutting dovetail tenons? Some guys re-grind skews to match the shape of their chuck’s dovetail jaws … maybe this is a shop-made variant of that?
View lew's profile
lew
12062 posts in 3756 days
#12 posted 10-08-2013 02:07 PM
“V” Scrapers
View JustJoe's profile
JustJoe
1554 posts in 2039 days
#13 posted 10-08-2013 02:23 PM
It might be home-made, but then it might not. I don’t think mine is and it looks just like those but bigger:
The color difference is just where I tried to sand away some of the protective varnish a previous owner had slapped all over it. The shape is the exact same. It’s 5/16” thick, 1-5/16th” wide. I can’t read the mark but it is a sideways diamond to the left of WORKS and what might be C&H. It is too big for parting anything smaller than a baseball bat, sucks at cutting like a skew, and is just a mediocre scraper. Based on its age, if it is to be used as a shear scraper then Ray Key “borrowed” a design from about 50 years ago. I haven’t found what it’s real purpose is so it’s been sitting in the scrap metal bin waiting until I find a need.
-- This Ad Space For Sale! Your Ad Here! Reach a targeted audience! Affordable Rates, easy financing! Contact an ad represenative today at JustJoe's Advertising Consortium.
Woodknack
#14 posted 10-08-2013 06:02 PM
I don’t see myself using these as-is, I have carbide diamond, square, and round scrapers, and a steel bull nose scraper.
They are carbon steel and I already have a carbon steel parting tool, it gets really hot and dulls quickly. The small one might make a useful beading tool. I have a few beading tools made from files but they are really hard and difficult to sharpen. The large would make a decent scraper or maybe even a decent skew.
Wildwood
#15 posted 10-08-2013 07:28 PM
Rick, my M-2 HSS parting tools het hot enough to burn wood, I do not get them that hot re-sharpening!
Bottom line, all turning tools generate heat in use, and need re-sharpening regardless of steel use to make them.
Now if run out and buy this machine can sharpen those carbide steel cutters too!
http://www.cuttermasters.com/portfolio/tradesman-dc/
-- Bill
