Best finish for sliding dovetail?
Forum topic by mummykicks posted 10-07-2013 06:47 PM 793 views 0 times favorited 2 replies Add to Favorites Watch
View mummykicks's profile
mummykicks
109 posts in 2000 days
10-07-2013 06:47 PM
I’m building a drafting table that has some 3” wide x 3/4” thick(?) dovetails that it will slide up and down on, and also will use a clamp block that will be used to secure it in place once it’s at the right height. The clamp block is just a 3” piece of the female side of the dovetail that gets cut in half so you can tighten it and take up all the clearance in the dovetail, and thereby secure things.
Question is, what finish to use?
The clamps will likely be in place for a long time in one spot, so I worry about it becoming glued together after a while.
Not sure if poly behaves this way or not. I don’t want anything too slick or the clamp might not hold as good as it could so oil/wax finishes are probably out.
I was thinking some arm-r-seal, since I’m using it on the rest of the table.
Suggestions would be welcomed
2 replies so far
View Richard's profile
Richard
1922 posts in 2888 days
#1 posted 10-07-2013 07:16 PM
Can’t be much help on the finish , but I remember Drafting Tables from High School Drafting class. Still prefer them to CAD Programs.
View crank49's profile
crank49
4032 posts in 3169 days
#2 posted 10-07-2013 07:45 PM
Satin Polycrylic (water based)?
It’s what I like to finish my jigs and shop furniture with.
