Shop made discs for PSA sandpaper
Forum topic by HuckD posted 10-07-2013 03:11 AM 850 views 0 times favorited 0 replies Add to Favorites Watch
View HuckD's profile
HuckD
311 posts in 1583 days
10-07-2013 03:11 AM
Topic tags/keywords: disc sander lathe psa sandpaper jig
I’ve been working on a disc sanding setup for my lathe. Almost finished with the table. I’ve made one 12” disc from melamine (on particle bpard). I’ve ordered and received 12” PSA in 4 grits.
So…I need 3 more discs. The one I made from melamine I screwed onto a large faceplate and trued it up. No problem. Does the melamine need to be prepared anyway other than a good cleaning – maybe with alcohol?
I can make my own threaded faceplates from wood which could be glued to plywood discs which I like better than screwing to a metal faceplate. If I make discs out of birch plywood, how should they be finished? Will there be a problem replacing the PSA once it is worn out?
All suggestions and advice will be appreciated.
-- Visit my Youtube Channel: https://www.youtube.com/playlist?list=PLFZY9FU6f7lo2tUgJOnqCzBV3qxJzAVDA
0 replies so far
