HVLP First Spray Help...
Forum topic by NorCalQ posted 10-06-2013 06:15 PM 965 views 1 time favorited 11 replies Add to Favorites Watch
View NorCalQ's profile
NorCalQ
17 posts in 1735 days
10-06-2013 06:15 PM
I’m test spraying some waterborne poly. When it goes on, should is end up looking a little orange peely or should it look smooth? To get it to look smooth, I have to lay it on rather thick. More air? More material?
11 replies so far
404 - Not Found
2544 posts in 2931 days
#1 posted 10-06-2013 07:08 PM
Sounds like you may need to either thin the poly or your flow is too high. What kind of HVLP system are you using?
NorCalQ
#2 posted 10-06-2013 07:16 PM
It’s a Capspray CS9100, 4 stage HVLP. I’m using General Finishes Hi Performance water based poly. Doesn’t seem very thick to me, but what do I know.
NorCalQ
#3 posted 10-06-2013 08:17 PM
Actually, it levels out nicely, thanks to the foregiving nature of poly I suppose. Does the poly really need to be thinned? Should it go on like glass and stay that way?
View distrbd's profile
distrbd
2252 posts in 2408 days
#4 posted 10-06-2013 10:37 PM
Lower your pressure and thin down your poly a little ,spray thin overlapping layers .
-- Ken from Ontario, Canada
View rrww's profile
rrww
263 posts in 2075 days
#5 posted 10-06-2013 11:33 PM
A lot of waterbase doesn’t “flow – out” quite as fast as solvent based products, if its flowing out and drying nice, you don’t have to worry.
View NiteWalker's profile
NiteWalker
2736 posts in 2539 days
#6 posted 10-07-2013 02:37 AM
That’s typical of waterborne poly; it’ll look a bit orange peelish, but if sprayed properly, will flow out beautifully.
NorCalQ
#7 posted 10-07-2013 03:05 AM
Thanks for the info. It’s my first time spraying, so I was flying blind. The only other sprayer I’ve ever used was an air brush and that was always color, not clear. Spraying clear was tough, not seeing what I was spraying and all. Now that I know I’m on the right track, I’ve got two bathrooms worth of cabinets to refinish, so wish me luck. Thanks for all the help!
NorCalQ
#8 posted 10-07-2013 03:09 AM
By the way…how do you spray on vertical surfaces? If you’re laying down a a coat on the thick side, how do you keep sags from forming?
View Jokker78's profile
Jokker78
136 posts in 1659 days
#9 posted 10-07-2013 03:17 AM
Lots of light coats. I just sprayed a book case. I laid about six light coats
-- Measure once, cut , measure again, cut and damn its still to short
Shawn Masterson
1325 posts in 1910 days
#10 posted 10-07-2013 12:22 PM
don’t thin. back off the material flow, and practice.
View CharlesNeil's profile (online now)
CharlesNeil
2385 posts in 3832 days
#11 posted 10-07-2013 12:42 PM
Shawn has it right, dont thin, back off on the fluid. You want a slightly white/bluish look when you are done spraying , this will tell you ,you are wet enough for a good level and flow out. If it looks a little “striped” dont worry, as long as you can look across the panel and the sheen is even your fine. Texture behind the gun is normal, the finer the texture the smoother it will lay out, the bluish tint is still an excellent indicator your wet enough.
