making a butcher block top nightstand
« back to Joinery forum
Forum topic by Jokker78 posted 10-04-2013 01:57 AM 1335 views 0 times favorited 3 replies Add to Favorites Watch
View Jokker78's profile
Jokker78
136 posts in 1666 days
10-04-2013 01:57 AM
I am fixing to start building a night stand for my son. I want to make a butcher block top for it. I have a kreg jig and a biscuit joiner , and glue ?
what would be the best way to join all the strips together ?
I am new to wood working.
I was thinking about just glue and putting slates on the bottom of it.
I is worm hole redoak or red oak with worm holes in it. It will be 17×17 with the slates cut down to 1.5 inches
thanks
-- Measure once, cut , measure again, cut and damn its still to short
3 replies so far
View mahdee's profile
mahdee
3874 posts in 1736 days
#1 posted 10-05-2013 02:01 PM
Yes, just glue them together with food grade glue. If you cut the strips at right angle, then you shoudn’t need to run it through sander to even it out, but normally they don’t come out perfectly level so, count on having to shave off some.
-- earthartandfoods.com
Jokker78
#2 posted 10-05-2013 02:06 PM
What do you mean at right angle ?
View DS's profile
DS
2895 posts in 2389 days
#3 posted 10-05-2013 02:38 PM
A Right Angle = 90 degrees…
Glue and clamps should be sufficient to put this top together.
Any other fasteners would be only to assist in lining up the pieces while clamping, but probably aren’t necessary on a top that would fit a nightstand.
