Surface Mount Bench Vise?
Forum topic by Eddie_T posted 10-03-2013 05:45 PM 1233 views 0 times favorited 3 replies Add to Favorites Watch
View Eddie_T's profile
Eddie_T
208 posts in 2072 days
10-03-2013 05:45 PM
Does anyone watch Rough Cut Woodworking? If so do you know what bench top vice was used to hold the ball and claw legs being carved for the Chippendale Foot Stool episode? It was metal, long enough to clamp the leg and appeared to be surface mounted on top of the bench. I looked on the Woodcraft site since they were a sponsor, but didn’t see anything similar.
3 replies so far
View tyvekboy's profile
tyvekboy
1752 posts in 3014 days
#1 posted 11-02-2015 04:54 PM
I didn’t see the episode. However, when I was doing cabriole legs, I used a lathe to hold the the piece while I worked on it.
I’m sure there are jigs you could make to hold the leg while you carve it. If you have (or make) a shaving horse, that could also be used to hold a leg while you carve on it.
-- Tyvekboy -- Marietta, GA ………….. one can never be too organized
View hhhopks's profile
hhhopks
651 posts in 2378 days
#2 posted 11-02-2015 05:56 PM
I don’t recall for sure but I think it was some kind of modified pipe clamp.
-- I'll be a woodworker when I grow up. HHHOPKS
View tnwood's profile
tnwood
258 posts in 3087 days
#3 posted 11-02-2015 07:01 PM
I think he was just holding the pipe or bar clamp in either the front or tail vise as I remember it. I do that with one of the square aluminum bar clamps (3 ft), clamp the leg top and bottom, and then use my face and tail vises to grip the rectangular bar at an angle suitable for using a rasp, scraper, plane, etc. It works very well as you can turn the leg in the bar clamp and adjust the angle using the bench vise.
