spraying deft
Forum topic by Jokker78 posted 10-03-2013 11:14 AM 1318 views 0 times favorited 12 replies Add to Favorites Watch
View Jokker78's profile
Jokker78
136 posts in 1599 days
10-03-2013 11:14 AM
Do you guys thin deft when spraying it? i will be using a HF gravity fed spray gun? if you thin it how do you come up with a starting ratio? i have sprayed minwax poly. I think i like deft better , but have never sprayed it
-- Measure once, cut , measure again, cut and damn its still to short
12 replies so far
View Dan Krager's profile
Dan Krager
3842 posts in 2136 days
#1 posted 10-03-2013 11:49 AM
I have sprayed Deft exclusively once I experienced it. It is SO easy to work, easy to handle, quick, durable and ultimately the smoothest feeling finish I have ever worked with. It’s just fun.
Depending on the temp, 10 – 20% thin with lacquer thinner. It’s really not that fussy if your gun is good, but it does flow out better if thinned some. I use two coats on a 220 grit sanded surface, denibbing with 320 stearate paper between coats. With that simple and quick prep, the last coat flows out and dries as smooth as glass. I use a semi-gloss patina.
Since it doesn’t scum over in the can or gun, I just leave it in the gun between uses. I wipe the nozzle with thinner and hang the gun. A brief stirring by swirling the gun and it’s ready to go again as much as a month later. When refilling the gun, I pour thinner in first and fill the gun (gravity HVLP) to within 1/2” of top. Swirl it a bit and go.
DanK
-- Dan Krager, Olney IL http://www.kragerwoodworking.weebly.com Just when you figure out where things are in the hardware store, they rearrange the store.
View hydro's profile
hydro
208 posts in 1653 days
#2 posted 10-03-2013 12:25 PM
Dan,
What kind of lacquer thinner are you using? The last time I tried to spray Deft (2011?) it congealed when I added the thinner. Unfortunately I do not remember the thinner ingredients. I had to clean out the gun with acetone to get rid of the mess.
In the past I never had problems thinning and spraying deft, so maybe they changed the formula to meet some VOC regulations???
-- Minnesota Woodworkers Guild, Past President, Lifetime member.
Jokker78
#3 posted 10-03-2013 02:24 PM
I have not used any yet. Out of a gun. In the past I brushed it or rubbed it on.
I was just getting information as to what to do before I start my project.
View lazyoakfarm's profile
lazyoakfarm
144 posts in 2699 days
#4 posted 10-03-2013 02:35 PM
Deft what? Don’t they make all kinds of finishes? I’ve never used any of their products. Im stuck on General Finishes, finishes.
Dan Krager
#5 posted 10-04-2013 12:44 AM
Deft lacquer is a floor finish over here.
I’m using off the shelf lacquer thinner from the local hardware, nothing special. Did you perchance use mineral spirits? That’s almost what it sounds like and that’s what would happen if you did. You could use acetone as a thinner for Deft and it does accelerate the drying. Deft has been loaded with retarders because it is a brushing lacquer by design.
DanK
hydro
#6 posted 10-04-2013 12:38 PM
Dan,
I did use “lacquer thinner” but I do know there are many different blends under that name. Acetone came to the rescue to clean things up but I do not like using that as a solvent. Too nasty for my preference.
John
View Finisherman's profile
Finisherman
227 posts in 1751 days
#7 posted 10-04-2013 08:03 PM
I’ve sprayed Deft out of my HVLP system. It works well, but I found that it needed quite a bit of thinning, on the order of fifty percent, in order to get it to flow out smoothly. Granted, I was still at the bottom of the learning curve where spraying is concerned at that point. If you are comfortable with your equipment, you can probably use less thinner. As for the deft congealing when the reducer was added, part of the problem may have to do with the fact that Deft doesn’t make a specific reducer for its brushing lacquer, at least, not as far as I know. I think that your best bet would be to start with a high grade medium lacquer thinner. Prior to thinning your whole batch of lacquer, add a small amount of your thinner to a slightly larger amount of deft in another container and allow it to sit overnight. Provided that there’s no sign of a problem with the mixture in the morning, you’re probably good to go.
Dan Krager
#8 posted 10-04-2013 09:35 PM
Man, I guess I’ve been really lucky, because I’ve never seen it congeal or go bad like that. I just grab a can off the shelf and use it!
DanK
View kizerpea's profile
kizerpea
774 posts in 2269 days
#9 posted 10-05-2013 12:05 PM
I have sprayed a lot of DEFT…HVLP never have thinned at all…
-- IF YOUR NOT MAKING DUST...YOU ARE COLLECTING IT! SOUTH CAROLINA.
View jumbojack's profile
jumbojack
1673 posts in 2526 days
#10 posted 10-06-2013 04:48 AM
I use lacquer exclusively. I love the way it looks. I love how easy it is to use. I LOVE THE SMELL. I sometimes cut it a bit no more than 20% depends on the weather. I NEVER spray when it rains. I spray with a cheap little gun called a Critter. It holds a pint in a mason jar. Many light coats are the key. Here in warm California I can get six coats in a day. I hit the project with some 300-400 wet dry just before the last coat. The last coat gets some 600-1000 grit love after a full day curing. Then some Johnson paste wax. I used to use Deft satin but have switched to gloss as it seems to lay out better. I can bring it back to gloss or any thing below that with sanding.
View pintodeluxe's profile
pintodeluxe
5565 posts in 2715 days
#11 posted 10-06-2013 04:59 AM
I have sprayed Deft brand poly with a gravity feed HVLP and a 1.5mm tip. I spray it out of the can on vertical surfaces (to avoid runs). I thin it 10% for spraying horizontal surfaces.
Works great.
View Fuzzy's profile
Fuzzy
297 posts in 3890 days
#12 posted 10-07-2013 05:11 PM
Get a decent viscosity cup … look up what your gun “likes” ... thin accordingly with whatever solvent the manufacturer recommends. I know, they tend to push their own products, and it may cost a few $$$ more … but, it is cheaper than all that stripper and labor which just may be the other option.
-- - dabbling in sarcasm is foolish … if you’re not proficient at it, you end up looking stupid … ... ...
